HAF32 case fans?Post Date: 2009-04-28 |
CloveMan3
Newbie Joined: 25 Apr 2009 Online Status: Offline Posts: 5 |
Topic: HAF32 case fans? Posted: 28 Apr 2009 at 9:10am |
Are the fans that come with the case substantial enough to get the job done or should I spring for the Chassis Airflow upgrade option (Upgrade Chassis With Zalman Performance Fans (Up to 6 Fans))? Also would the Zalman fans be the same size as the HAF32 fans or would they be smaller and just more of them?
DST4ME
Quote Reply Posted: 28 Apr 2009 at 5:01pm |
the HAF comes with 3 x 230mm fan, zalmans are 120mm fans
airflow upgrade depends on what you are getting, most time the HAF stock is good. |
