H20: HydroLux Level 5: Digital Storm Exotic Custom
Post Date: 2014-10-31
KingHeikir View Drop Down
  Quote KingHeikir Quote  Post ReplyReply bullet Topic: H20: HydroLux Level 5: Digital Storm Exotic Custom
    Posted: 31 Oct 2014 at 5:57pm
Hi everyone,
Just wondering is there any maintenance needed on the Digital Storm custom water cooling thingy, I know there's a like a water tank & a pump that pumps the water to the core components of the computer, but does that water eventually dry up, & do you need to add more water, or is it like zealed & that water enough for the life time usage of the computer?
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 31 Oct 2014 at 7:12pm
I think with the exotic liquid systems they do need to be maintained every now and then although not sure how long you have to go between maintenance.
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
  Quote KingHeikir Quote  Post ReplyReply bullet Posted: 31 Oct 2014 at 8:22pm
Thanks for the answer,
Just a side question.
Is that really required for the GPU's, or just a way to decrease the heat and able to OC the GPU's?
Because when you pick Aventum II ultimate it has this exotic custom cooling thingy only for the CPU instead for 2 GPU's because the ultimate prefit has 2x Titan Z's.
So the question is do you really need it or is just for OC'ing & better cooling?
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 31 Oct 2014 at 8:34pm
You don't really need it but its there if you want the option to use it, i think its mainly personal preference really. But i also think its just for higher overclocks and better cooling.
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
This page was generated in 6.896973E-02 seconds.
