Ironwolf1974
Posted: 02 May 2012 at 10:21pm |
Originally posted by josephlee
That was pretty cool, thx for sharing |
No problem man. Just wish my cam skills were better :P
This machine is sweet. Rock solid 4.5ghz overclock. Ive run BF3, Skyrim now so far in super ultra everything on settings in 3D and flawless performance.
Ironwolf1974
Posted: 03 May 2012 at 8:14am |
Should my CPU temps be running into the low 80s?!
Posted: 03 May 2012 at 8:52am |
You have the i7-3930k? Usually, in general, a temp below 85 is safe but the 70's is better. Both rad fans are spinning? What's the room temp? TJMax on that chip I think is 91c. Low 80's seems close, but is safe. Check temps and fan speed with HWMonitor and temps and distance to tjmax with RealTemp. What speed do you have the H100 set to?
Edited by bprat22 - 03 May 2012 at 8:54am
josephlee
Posted: 03 May 2012 at 9:30am |
Ironwolf1974
Posted: 03 May 2012 at 3:18pm |
Room temp is about 70. How do I set the H100 speed?
Ironwolf1974
Posted: 03 May 2012 at 6:28pm |
Ok so opened the case and found the push button on the H100, set it to max, which I might add is REALLY LOUD! lol.
Anywho, max temps on BF3 in 3D, super ultra everything on was 79c on one of the cores. This is safe your saying Bpratt22?
Posted: 04 May 2012 at 3:45am |
That's a safe temp...We like to see a few degrees better but every chip is different. I would think the H100 on medium, to stay quiet, would do it, but, again, some chips just run differently. You could call DS and run this by them. They'll tell you how it setup during testing and give you a better comparison history of what they encounter than we can.
Ironwolf1974
Posted: 04 May 2012 at 12:20pm |
You could call DS and run this by them. They'll tell you how it setup during testing and give you a better comparison history of what they encounter than we can. |
Thanks for all your help man! Its been very nice :D
I havent called DS yet, going to probably get some pic's together and post a review in there reviews section.
Right now if I put it on high, the H100 (why the heck is there no external control for it Ill not ever know), I can stay under 70c in intense long term gaming sessions. So Im good with that for sure.
josephlee
Posted: 04 May 2012 at 1:59pm |
Yeah, can't ask for much more than that.
Posted: 04 May 2012 at 2:07pm |
Hi Ironwolf1974,
If you are getting below 70c then you are rocking. Glad your system is up and running.
Posted: 04 May 2012 at 3:57pm |
Ironwolf1974.....So glad it's working. Nice job.
Ironwolf1974
Posted: 05 May 2012 at 1:08am |
Not impressed with the H100 so far.
At 100% it peaked at 85c while doing some BF3.
Maybe I just got the wrong cooler, but so far just not impressed.
Posted: 05 May 2012 at 4:25am |
Sorry to hear. I thought it was under control. Next week, I would call DS and see if tweeking the overclocking will drive the temps down. I wouldn't think any thing over medium setting on the H100 would be need, both for noise and cooling. They might say that 6 core chip runs like that with most builds, but I'm not sure. Let us know and good luck.
