Hi Ymbert....... Welcome to the forums.
That is a real nice build you put together. For your budget I would suggest checking out the ODE level 4 which had a sli, 2x gtx670 to max out anything you throw at that monitor.
If you want to keep a custom config because of the larger SSD and HDD and you don't like a white 600T case in the ODE then here's a config to look at.
Config # 714567 Cost $ 2209
Chassis Model: Special Deal Hot Seller - Corsair 600T
Hard Drive Set 2: Multimedia\Data: 1x (2TB Western Digital (7200 RPM) (Model: Black Edition) (SATA 6Gbps)
I dropped the cpu to the i5-3570k to save some money. The 3770 is a better cpu but for strickly gaming the 3570 is all you need.
The sabertooth mobo will also save you money and has a 5 year warranty vs 3 year for most others. Unless you want the WiFi feature of the Deluxe then the sabertooth is all you need.
You only need 8GB of ram for gaming. 16GB doesn't hurt but for the most part in games will not be needed.
I do like the Noctua D14 cooler better than the ODE 4's Vortex 240mm cooler for tops in reliability. The Vortex is nice and has a good track record but the D14 leaves little to go wrong.
I dropped the noise suppression package. Just wasted money in my opinion.
I put in stage 1 overclocking. No sense having a great cooler like the D14 if no oc. Stage 2 is also very do-able but I left it at stage 1 because of your doubts.
The air cooler and the Vortex 240mm cooler both use fans for cooling. The D14 has a big block of fins the fans blow through and the Vortex has a 240mm radiator the fans blow through.
This config with the price chopping does give you room to add a sli, 2x 670 like the ODE 4 for about another $80 over your config, I believe. The single gtx670 will play most games maxed with good fps, and other games like BF3, etc on high settings . High settings is great gaming so the single 670 migjht be all you need.
If you went to the sli 670 then the 1050HX psu for more money would be better. The 800w does work but doesn't leave much headroom.
For the money you can't beat the ODE 4, but the custom does give you more flexibility to add different coolers, HDD, SSD, etc.
Edited by bprat22 - 02 Aug 2012 at 9:24am
