Gaming/Design Build HelpPost Date: 2012-05-23 |
Valkyrie
Newbie Joined: 23 May 2012 Online Status: Offline Posts: 10 |
Topic: Gaming/Design Build Help Posted: 23 May 2012 at 6:10am |
10,000 (including monitor, mouse). If more is needed for liquid cooling than that's alright. Expectations: Best possible gaming/design build for budget. I need it to be able to supply the best possible gaming experience, including PhysX e.t.c. I also need it for 3d rendering and tablet graphic design. I'd like it to be very fast when processing. Usage: Primary: High-Quality gaming(will be used for MLG). Secondary: Game design (3D modelling and rendering, tablet graphic designs). Will also be used sometimes for server hosting (needs a lot of RAM). Special Needs: Australian power supply. I really need a surge protector but they're all American outputs. As stated above, high quality RAM. I'd like the best possible monitor and keyboard/mouse for gaming (I can't choose). Windows 7 Ultimate or similar (so it can actually handle a large amount of RAM). I'm not sure what type of cooling I need, I'd like this computer to last quite a long time. Current Specs #: /comploadsaved.asp?id=691572 ------------------------------ Sorry about my poor post structure - it's my first time doing this sort of thing. I hope you can help me achieve the best build and I look forward to your responses. If you submit help, can you also judge fellow community members inputs as well please? I saw a dual processor a while back and it looked really awesome. Thanks for your time! Regards, Troy Edited by Valkyrie - 23 May 2012 at 6:10am |
Giving up is the only failure in life.
hotshot146
Groupie Joined: 24 Jun 2011 Online Status: Offline Posts: 128 |
Quote Reply Posted: 23 May 2012 at 6:59am |
First thing you will have to call and see if they can order a Australian psu. The ssd you picked for storage has known problems with the controller. I changed the 2 120Gb to 1 intel 240 Gb one and removed the raid. the raid 0 would cut your storage in half and if one drive goes bad you will lose all data on both drives. I also changed the cooling to be water cooled video and chipset. For your budget it will be a good thing to get. I also took off the video card overclock because they do not overclock them very much and will make the GPU die faster.
Here is config number 691584.
Edited by hotshot146 - 23 May 2012 at 7:01am |
Valkyrie
Quote Reply Posted: 23 May 2012 at 7:57am |
Thanks so much for the input! It sounds a lot more efficient than my primary config. Will removing the RAID option cut down the processing speed? Regards, Troy |
Valkyrie
Quote Reply Posted: 23 May 2012 at 8:05am |
Also, is 16GB DDR3 2133MHz Corsair Dominator GT with DHX or 32GB DDR3 2000MHz GTX-8 Digital Storm Certified Performance Series better?
xii
Quote Reply Posted: 23 May 2012 at 8:09am |
Sir/Ma'am,
I suggest the following build: Chassis Model: Special Deal Hot Seller - Black OPS Aventum Exterior Finish: - Standard Factory Finish Trim Accents: - Not Available Processor: Intel Core i7 Extreme Edition 3960X 3.3GHz (Six-Core) (Extreme Performance) Motherboard: ASUS Rampage IV Extreme X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 32GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) This changes the operating system suggestion ^ Power Supply: 1500W Silverstone (Dual/Triple/Quad SLI Compatible) (Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (240GB Solid State (By: Intel) (Model: 520 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Slim Slot Loading Edition) Optical Drive 2: - Not Available Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 3x SLI Triple (NVIDIA GeForce GTX 680 2GB (Includes PhysX) (EVGA) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: Digital Storm Aventum Liquid Cooling System: CPU + Video Cards + Chipset <= you won't need the subzero liquid cooling (which is better) because the modular cooling design of the aventum will take care of the 'extra' heat your currently liquid cooling system will provide. H20 Tube Color:Red Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: - Not Available Internal Lighting: Internal Chassis Lighting System (Red) <= red by default Enhancements: - Not Available Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) <= windows ultimate is really pointless in my opinion, they just add digital locker options and a XP virtualization which you would rarely use and even then, I find it doesn't work well from my experience. The Professional Edition allow you to use the amount of ram you have selected - this is your operating system floor in my opinion. Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks <= I removed this - if you want good anti-virus get ESET's NOD32. Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks The following were selected from what they had to choose from: Speakers: Corsair Vengeance 1500 USB Gaming Headset (Model CA-9011112-WW) ^I personally would find a vendor and buy a nice set of skull candy - really sound is preference you just need to listen, if you talk on voice then get a set with a good mic. Noise canceling. Keyboard: Logitech G19 Gaming Keyboard (USB) (920-000969) <= Love these keyboards, take note however, they are big. Mouse: Corsair Vengeance M60 (Laser 5700 dpi) (FPS Gaming Mouse) (USB Wired) External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) <= Now you can wear the Digital Storm Flag! 100 percent likely to attract people of the opposite sex! (disclaimer: Unless they do not like shirts, whereas all percent is hereby void ;-) ) Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Special things to know: Digital Storm is an awesome company. You'll need to contact them to talk to them (even though the forums are awesome) because you have things, like the power supply you'll need. Also know, you may send THEM stuff so if you get a 1500w PSU and send it to them, they should be able to work with that, however again, ask them. If you do go that route - do research. I have a buddy that lives in Queensland if you want me to inquire? The system is listed at: $8105.00(usd) which would make your system roughly 8,341.73(aud). Also note I chose a random monitor for you. Are you going to game 3D? If not: A Dell Ultrasharp - mmmmmm! I hope this helps you. Oh and if you run into me in the PGL - watch out. ;-) |
xii
Quote Reply Posted: 23 May 2012 at 8:10am |
You want to take the 1600hz memory the 2133 and whatnot have issues from overclocked processors I am told. |
Valkyrie
Quote Reply Posted: 23 May 2012 at 8:28am |
Thanks so much for your insights! It was extremely helpful and I had a laugh at the same time (: I'll put some thought to your supplied config, it's quite appealing at the moment. I'm hoping I might be able to increase my budget a bit more, the next few days will tell. I came across this YouTube video as I was typing this and I'm thinking that it's going to void any new computer I get... Unlimited Detail - Realtime Graphics P.S. If you don't play it already, give Tribes: Ascend a go. It's really addictive and claims to be the most fast-paced shooter at the moment. |
xii
Quote Reply Posted: 23 May 2012 at 8:44am |
Yea Ive been following that group for a year or two now. I don't see their tech on the market for a decade. So much red tape and greed has to be played through first. Such is business.
Anyway! I cant wait to see your final decision! |
Valkyrie
Quote Reply Posted: 23 May 2012 at 9:08am |
I hope you don't mind me asking a final question. What is your view on internet access? I was looking at the Killer 2100 Lag and Latency Reduction, but I'm not sure it would be useful here in Australia. |
xii
Quote Reply Posted: 23 May 2012 at 9:25am |
Im biased on KillerNic. I've had nothing but problems with them.
I own a total of 6 PCs (desktops and laptops) 4 have KillerNic's all of them are disabled. They fail, the control engine is a PITA and otherwise I notice to performance gain. I have however noticed performance loss. Your mileage may vary. |
Valkyrie
Quote Reply Posted: 23 May 2012 at 5:28pm |
What do you think about: http://www.digitalstormonline.com/comploadsaved.asp?id=691856? I left the KillerNic by accident, I'll just get the high-speed one.
Edit: Concerning Hard-drive 1, you mentioned the 240gb SSD by Intel. Should I get that one or the 1x (180GB Solid State (By: Corsair) (Model: Force GT Series CSSD-F180GBGT-BK) (SATA 6Gbps). I know it has a little less memory, but wouldn't the speed compensate? I'm a bit of a noob when it comes to SSD's so I have no idea Edited by Valkyrie - 23 May 2012 at 5:43pm |
Asangard
DS Veteran Joined: 21 Aug 2009 Online Status: Offline Posts: 2209 |
Quote Reply Posted: 23 May 2012 at 6:17pm |
Hi Valkyrie
The Intel 520 series SSDs are faster than the Corsairs and have a longer warranty. 3yrs for the Corsair Force GT and 5yrs for the Intel 520s.
Not from Without, Therefore, the 1st step on the Holy Warrior path, Is to recognize thyself as thy 1st enemy. |
Valkyrie
Quote Reply Posted: 23 May 2012 at 6:29pm |
Sweet, thanks for the fast response. By the way - do you know what payment methods DS accepts? |
xii
Quote Reply Posted: 23 May 2012 at 9:20pm |
The Corsairs also dont last as long as the intels as far as lifespan Im told.
As far as payment - they do credit cards - wire transfer, direct deposit, check or purchase order.. I think thats all of them.. Need specifics specific? Edited by xii - 23 May 2012 at 9:22pm |
Valkyrie
Quote Reply Posted: 24 May 2012 at 8:45pm |
Thanks again. All I needed were the different options. I sent DS Support a message inquiring about the PSU, but haven't got a response yet. It seems like they're never on Live Support, probably time zone difference though. |
xii
Quote Reply Posted: 24 May 2012 at 8:54pm |
Yea um.. lets see. They'll be open at 12ish for me so thats.. 2am ish for you?
Which means for you... if you live in queensland.. itll be nearing sat.. so they will be open if you call them at like 2 am or later. On your sat. Approximately. Man my head hurts now. I'd email alex - but I'll respectfully let him open that door. |
Valkyrie
Quote Reply Posted: 25 May 2012 at 2:05am |
My head hurt when I was trying to work out the time conversion as well haha. I'll just email support rather than leave a ticket. |
Valkyrie
Quote Reply Posted: 28 May 2012 at 11:24pm |
Heyo, I'm down to buying now and I actually may need some specifics. What are the "specific specifics" for Credit Card, Wire Transfer, Direct Deposit and Purchase Order? As in, what is the process of payment? Which is more convenient (faster) and safe? I'm not sure what the limit is on my credit card, but I hope it's $9,200. P.S My final build is http://www.digitalstormonline.com/comploadsaved.asp?id=693631. Edit- The problem is that they only have options for shipping to the U.S and Canada, so how am I going to get shipping to Australia? I really don't want to pay 10% GST for it, it basically rules out the DS 10% discount. If you'd do a final review I'd be grateful! :D Edited by Valkyrie - 29 May 2012 at 12:00am |
hotshot146
Quote Reply Posted: 29 May 2012 at 3:31am |
It looks good you still have the Killer card in the card (Just wanted to make sure you knew it was there and not forgot a out it). For shipping you would have to call/email them to get prices. The fastest way to pay would be credit card. But at 9000 I would look into wire transfer all you will have to do would be to go into your bank and give them the account info of digital storm.
hotshot146
Quote Reply Posted: 29 May 2012 at 3:37am |
One last thing if you do pay by credit card you will have to fill out a form with copy of credit card (front and back). I brought a PC for
about 8000 during Christmas and had to do it. |
xii
Quote Reply Posted: 29 May 2012 at 7:50am |
The above information is correct. Credit on high amounts of money will require you to sign what is basicly a release of funds authorization form.
I agree with wire transfer as your option - as far as that killernic goes (again my opinion) you are wasting your money. As far as shipping, well - best bet is to email DS or call. I'm unaware of international shipping policy. |
