Game Front: Bolt II Review - October 2014
Post Date: 2014-10-24
  Quote Alex Quote  Post ReplyReply bullet Topic: Game Front: Bolt II Review - October 2014
    Posted: 24 Oct 2014 at 1:20pm
For a PC, the Bolt II is small — almost tiny. It’s about 16.5 inches tall, 14.25 inches deep, and only 4.5 inches wide. While that is bigger than either the PlayStation 4 or Xbox One, it’s not substantially so. The custom-designed case also features rubber feet on standoffs on the left side, allowing you lay the case horizontally, or place it vertically against the side of your entertainment system without having to worry about obstructing airflow. It’s smaller than my surround sound receiver, making it a good fit in the living room.
Read Review: http://www.gamefront.com/digital-storm-bolt-ii-review-good-things-in-a-small-package/
Roykirk View Drop Down
  Quote Roykirk Quote  Post ReplyReply bullet Posted: 24 Oct 2014 at 1:58pm
Review seems to imply that the Bolt II was designed to be a Steam Machine? Confused That doesn't sound right.
In any case, another kudo for the Bolt.  Go, DS! Awesome
  Quote Alex Quote  Post ReplyReply bullet Posted: 24 Oct 2014 at 2:42pm
Many press outlets first noticed the Bolt II as a Steam Machine, but it's actually far more than just that. It can be a Steam Machine no doubt!
