Function KeysPost Date: 2013-07-10 |
bighunt
Newbie Joined: 22 Feb 2013 Online Status: Offline Posts: 20 |
Topic: Function Keys Posted: 10 Jul 2013 at 1:11pm |
I have a minor annoyance.
My function key works, but it does not show up on my screen when I raise/lower volume, screen brightness, etc. The drivers are up to date. Restarting computer doesn't help It's not a huge issue, but I'd like t see the volume bar when I adjust the speakers volume. Any ideas on what I could do? Thanks. Specs: 15.6" Laptop Windows 7 HP Intel i7 3740QM cpu 16GB Ram 128 GB SSD 2GB AMD 7970 |
Quote Reply Posted: 10 Jul 2013 at 2:12pm |
From what I know, I do not think the laptops an on screen thing showing volume levels.
bighunt
Quote Reply Posted: 11 Jul 2013 at 5:52am |
They do on my Sony Vaio laptop.
Quote Reply Posted: 11 Jul 2013 at 8:18am |
There is a driver for the Hotkey function that the manual shows for the Clevo, which is what DS uses, that allows visual indicators to appear. It should be on the disc, but what the visual indicator is I can't say. Wish I had one to try out.
Check the manual and disc and just double-check the Hotkeys driver is loaded. Good Luck.
