Fixed problem, but questions
Post Date: 2015-02-22
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Topic: Fixed problem, but questions
    Posted: 22 Feb 2015 at 7:18am
Good morning all,
So I got back from work last night, computer had hibernated while I was gone. Decided I'd just leave it until morning. Fast forward to an hour or so ago, and I woke up the rig, but then it just went into a cycle of turning off and back on repeatedly, with no monitor activity.
I turned it off, then back on, but again, no monitor activity. Ultimately read online to remove the CMOS battery from the motherboard, put it back in, and try again. It worked! Felt good to dig around in the computer, albeit slightly stressful about ruining something.
Upon booting, it stopped at the Bios screen, telling me there was a problem with the CPU fan. I went into the settings, didn't want to change anything for fear of ruining the work DS did in setting it up for me (overclock, etc), and then it booted up just fine.
My question to you all is, what could cause this issue in the first place? Should I be concerned? I'm monitoring temps in the control center, it looks like the CPU is holding steady around 77° F. Is this normal?
Edit: and since posting with WoW running, it has risen to 80. Roughly 1 degree every 2 minutes. I imagine this is minor, but nervous nonetheless. I feel like I've never seen my CPU even hit 80 >.>
Thanks!
Edited by Eggy - 22 Feb 2015 at 7:27am
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
HydroLux Level 4 (3x GPU + CPU. No chipset)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:26am
HI Eggy.... With your water cooling, the cpu_fan header on the mobo above the cpu isn't used.   If no fan is plugged in there then the Bios thinks you lost the cpu cooling fan.
Go into Bios and under Advanced screen and Monitor tab, I believe, look for CPU FAN  drop down and set to Ignore or something similar.   Your mobo manual will help if I'm a bit off.  Big%20Smile
Do you still have your overclock?   When resetting CMOS, the Bios will reset to Default and usually drops the DS oc.    Under Tools tab in Bios, again check the manual, will be the OC Profiles that DS saved.    Restoring that should also set the cpu fan back to ignore.
Check the oc first with cpu-z or whatever you use.
Hope this helps. Big%20Smile
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:33am
So this is what I'm seeing in cpu-z? Forgive me, I'm not sure how to determine if the OC is there. Is that the "multiplier" down in the clocks section?
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:33am
Your temps......Do you mean 77-80 F or C.  Just read the Centigrade value.   Ignore the Fahrenheit.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:35am
I can't open that.   In the CPU-Z screen, the lower left has the Core Speed in Mhz.  When the cpu is stressed, that figure to go to, for example, 4400Mhz, if your oc is 4.4Ghz.
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:35am
Farenheit. Pulled up Afterburner - CPU temps are ~10-16 centigrade depending on the core.
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:37am
Excellent temps.  Big%20Smile
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:46am
Got the DS profile loaded, CPU-Z is showing the difference now. Thanks as always, bprat!
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:48am
My pleasure.  Big%20Smile
The fan fault is also gone?
Nice job, Eggy.
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:48am
So, what, if anything specifically, typically causes the no signal issue? Tried different ports, unplugged power cables, etc, so I'm not sure what the other fix aside from the battery would have been.
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 7:52am
Can't say for sure, but I never recommend sleep or hibernate.    Lots of people use it with zero problems and others just can't use it.  You got me.
Instead of the CMOS reset, sometimes unplugging the rig from the wall, holding in the front panel power on button for 10-15 seconds, will clear any faults floating around.
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 9:33am
Oops, missed that other one - yes, no error messages at the bios screen regarding the fan, so all seems to be well. CPU-Z shows ~4.4 clock, and the settings in the bios showed that stuff as well.
Yeah, I don't typically use hibernate or sleep, I guess I just never changed that setting. Fixed now Big%20Smile
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 10:44am
Great. Awesome
michaeljhuman View Drop Down
  Quote michaeljhuman Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 12:45pm
Not that my computer will ever show up, as I have been waiting 6 weeks for it, but I also chose the 5930k, and wondered what you specified for OC on your purchase?
I would be very pleased if I get 4.4 Ghz with mine
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 1:27pm
Until Eggy comes back..... I believe he selected stage 2 oc and DS got it to 4.5 or so.
But, he can say for sure.
  Quote michaeljhuman Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 1:47pm
I wonder what they do different on a stage 2 overclock?
Like stage 1, is no change to voltage, and stage 2 they increase voltage and perhaps other things?
It would be nice to know more about the difference.
I have it down for stage 1, as it was a default. I can certainly raise voltage myself and try for more. but I don't know anything fancier than a simple voltage boost
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 1:58pm
I can't say exactly what they do, but even at 4.4 there is a vcore increase, probably around 1.3.     DS goes for a modest oc because the difference between 4.4 and 4.6 , for example , is little real world difference.   With water cooling the added heat from a higher vcore can be better handled, but higher vcore is still more stress on the chip.   Voltage does kill.
  Quote Alex Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 3:20pm
We do minor voltage changes on Stage 1, but it's much more aggressive on Stage 2. However, please note, we don't push the units too hard on overclocks.
  Quote michaeljhuman Quote  Post ReplyReply bullet Posted: 22 Feb 2015 at 5:26pm
Thanks for the info
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 23 Feb 2015 at 2:40pm
Sorry for the delayed response Michael, woes of "busy season".
I requested/paid for the stage 2 overclock. As Alex said, while the stage 2 is much more aggressive, they don't try to push the limits. I wound up with roughly a 4.5ghz speed after the overclock.
Considering how easy it is to ruin a processor with OC'ing, I'm perfectly happy with 4.5. Stock clock is 3.5 for the 5930k I believe, so an extra 1.0 on top of that is absolutely acceptable in my book. I'd much rather a stable 4.5 than a push for 4.7 which could ultimately ruin the component.
If you selected Stage 2, I'm sure they could get you to 4.4 at least. And I think you're going to be very happy with the result Strong
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
  Quote michaeljhuman Quote  Post ReplyReply bullet Posted: 24 Feb 2015 at 12:44am
If they are not doing anything too fancy, I should be able to overclock it to roughly the same level they would on stage 2.
Will be curious to know what clock I get for level 1
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Feb 2015 at 3:40am
From past posts, an oc of about 4.3 and 4.4 is typical for stage 1.   The other thing is, if you oc it yourself and have issues or cause a problem, DS warranty won't cover it. Having them oc it gives you their warranty and support for the added money.   But, check with them because I remember this from a year or two back.
Eggy View Drop Down
  Quote Eggy Quote  Post ReplyReply bullet Posted: 24 Feb 2015 at 7:54am
What bprat said.
If you're planning on OC'ing the chip anyway, doesn't make much sense to pay for them to do it in the first place, especially since you may void the warranty  by playing with it.
"King Solomon"
Hailstorm II
Intel Core i7 5930k
16GB DDR4 2666MHz
Rampage V
3x GTX 980
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Feb 2015 at 11:19am
Thread moved to hardware discussion.
This page was generated in 7.421875E-02 seconds.
