First High End Gaming PC, help!
Post Date: 2015-03-03
PoliteStranger View Drop Down
  Quote PoliteStranger Quote  Post ReplyReply bullet Topic: First High End Gaming PC, help!
    Posted: 03 Mar 2015 at 6:46pm
[$2000]
[I want to run things like Minecraft, DayZ, H1Z1, Oblivion, etc HIGHEST SETTINGS 0 LAG/ZERO FRAME DROP.Will be live streaming to twitch while playing games like this so keep that in mind. Upload speed is around 4mb/s]
[Will be using for a plethora of Steam Games like the ones I listed above, also I am a huge video editor so I need to be able to render HD videos very fast and have 0 lag when editing and previewing video. Also I will be running this computer on 2 24" BenQ rl2455hm monitors.]
[Budget is 2k but if you think I don't need to spend that much for what I plan on doing by all means tell me. ]
Saved Ticket #: [Please Type Here]
[Inform and enlighten me!]
Edited by PoliteStranger - 03 Mar 2015 at 6:49pm
To Water on Mars
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 03 Mar 2015 at 6:55pm
You can change the chassis to your preference. This should be the best system for your needs for the budget. BTW, with the special offer, if you add $35 of options to this, it'll only cost you $10 more...if you need an ODD, add one; or upgrade the SSD to the 250GB model for more space and performance.
Configuration URL:     https://www.digitalstormonline.com/configurator.asp?id=1157585
Chassis Model: Special Deal Hot Seller - Cooler Master K380
Motherboard: GIGABYTE Z97X-SLI (Intel Z97 Chipset)
System Memory: 16GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Power Supply: 750W EVGA SuperNOVA
Optical Drive: - No Thanks
Storage Set 1: 1x SSD (120GB Samsung 850 EVO)
Storage Set 2: 1x Storage (2TB Western Digital - Black Edition)
Storage Set 3: - No Thanks
RAID Config: - No Thanks
RAID Card: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (Includes PhysX)
HPC Processor: - No Thanks
Extreme Cooling: !CLEARANCE: AIR: Stage 2: Noctua NH-D14 SE2011 Extreme Performance
Airflow Control: - No Thanks
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
Edited by  - 03 Mar 2015 at 7:00pm
  Quote PoliteStranger Quote  Post ReplyReply bullet Posted: 03 Mar 2015 at 8:28pm
Looks brilliant, is there a big difference in performance between the NVIDIA GeForce GTX 970 4GB and the 980?
To Water on Mars
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 03 Mar 2015 at 9:29pm
The 980 have maybe a 10% performance advantage over the 970, but costs a bit more. Up to you whether it is worth it or not. Dual 970's in SLI would be a better deal, still.
Search for benchmarks of the games you want to check online and compare how 970's and 980's perform.
This page was generated in 5.297852E-02 seconds.
