This is a custom config to compare to ODE 3
Config # 659427 Cost $ 2653
Motherboard: ASUS P8Z68-V PRO/GEN3 (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 520 Series)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Tech) (EVGA 012-P3-1571-BR)
This builds is $300 more than ODE 3 for basically the same gaming performance.
What you get with the custom config is a better case for cooling, the HafX......
....a psu, the 1050HX, with a 7 year warranty and more power for future upgrade.
and a better cpu cooler, D14,, very reliable and tops.
You'd have to decide if the added cost is worth it. The ODE 3"s psu and case and cooler are very good and will definitely do the job, no worries there.
Compared to your build, The ODE 3 gives you sli gtx 570 for the same cost.
Your i7-2700k is no better than the i7-2600k.
Your psu is better rated, but the 800W is good and comes with a 5 year warranty. The ODE case I would prefer over your pick. The ironclad would be noisy with the 120mm fans front, top and back. Larger fans like the HafX and ODE's 200mm fans spin slower for the same air flow thus less noise.
And the Extreme mobo is lots of $$$ for features you might never use. You'd have to compare features on Asus website and see for your own needs. For most the Extreme mobo is just the best but not the most practical.
Check it out and see what you think.
Edited by bprat22 - 25 Feb 2012 at 4:12am
