First config with Digital - Input desiredPost Date: 2012-10-01 |
Dohfugwimee
Newbie Joined: 01 Oct 2012 Online Status: Offline Posts: 2 |
Topic: First config with Digital - Input desired Posted: 01 Oct 2012 at 10:23am |
Please critique and advise!
Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Processor: Intel Core i5 3570K 3.40 GHz (Unlocked CPU) (Quad Core) (Requires Z77 Motherboard) Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) (Does Not Support SLI) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 800W Corsair GS (Dual SLI Compatible) Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps) Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: !PROMOTION: 1x AMD Radeon HD 7950 3GB Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) Chassis Airflow: Standard Factory Chassis Fans Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Video Card: Yes, Overclock the video card(s) as much as possible with complete stability Boost OS: FREE: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) |
Quote Reply Posted: 01 Oct 2012 at 11:00am |
Hi Dohfugwimee...... Welcome to the forums.
That's a nice rig. Not much to say. I would suggest dropping the free Boost Oc option. I don't know what they tweek but the pc comes in bloat free and I'd rather pick and choose myself. But that's me and your choice as always. I prefer the gtx670 for a bit more and it does perform better with alot of games, but the 7950 is also a great card. Here's a link comparing the two. You can also change the cards around to compare the 7950 with the 660Ti, etc. Not sure what you play or the monitor size and resolution but the chart should help. Don't forget your free t-shirt. Good luck.
Edited by bprat22 - 01 Oct 2012 at 11:01am |
