Fan Configuration
Post Date: 2012-05-10
hujh2012 View Drop Down
  Quote hujh2012 Quote  Post ReplyReply bullet Topic: Fan Configuration
    Posted: 10 May 2012 at 8:02pm
Alright, I have recently installed a 2nd Radeon 6950 in my Cooler Master 430 Elite Chassis. It's a mid tower case and with the two cards in there it's a pretty tight fit. Being so, there is only a small gap between the top and bottom card making the top card get much much hotter (10-20 degrees Celsius more) I have a side fan that I recently purchased as well and there is a spot on the side of my case for it. Should I have it as intake to blow cool air on my gpus or as exhaust to pull hot air off of them to help remedy the cooling issue?
gostyleshop       Replica Dolce & Gabbana Shoes
This page was generated in 3.808594E-02 seconds.
