evga gtx 580 hydro
Post Date: 2012-03-06
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Topic: evga gtx 580 hydro
    Posted: 06 Mar 2012 at 10:23pm
with the 2x SLI Dual (NVIDIA GeForce GTX 580 3GB EVGA Ultra Hydro Copper what cooling setup do i need. i am confussed on whether i need the dual sli setup because the gtx580 already has water cooling block. i want to cool cpu, mobo and Graphics.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 07 Mar 2012 at 4:15am
Go to Extreme Cooling in config, hit red Expert Mode and the stage 6 options open up, with the cooling for gpu, chipset, etc.
  Quote tju76 Quote  Post ReplyReply bullet Posted: 07 Mar 2012 at 6:16am
what i am trying to ask is why do i need to pay more money for the water cooling blocks for stage 6 dual sli, when the graphic cards that i selected already have built in water blocks, it seems like all i would need in the LC setup would by the cpu, and mobo cooling and then tubes going to the cards. lol LC is a nightmare
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 07 Mar 2012 at 6:40am
Here is a quote I pasted from EVGA website.
This card features a preinstalled EVGA Hydro Copper water block that accommodates both 1/2" and 3/8" water cooling loops. Upon first glance you will notice this is no ordinary water block, this is a full cover- end to end block, with an integrated glowing window that displays the water flow and a glowing EVGA logo on the side keep it looking slick. Also, a preinstalled EVGA backplate keep the card sturdy! The innovation does not stop at stability an appearance however; the base plate is made of chrome plated electrolytic C110 copper, and the 0.6mm thin pin matrix provides optimal thermal transfer to ensure the lowest temperatures possible
I'm not up on lc systems, but it appears the Hydro does have a built in waterblock and only lines to it are needed..  Now how DS would charge for this with the gpu's already having the waterblock installed I can't say.  Call DS and they would be happy to tell ya or maybe someone that knows can chime in.
Edited by bprat22 - 07 Mar 2012 at 6:40am
  Quote tju76 Quote  Post ReplyReply bullet Posted: 07 Mar 2012 at 7:34am
thank you very much
