dust removal on Vanquisher IIPost Date: 2014-11-17 |
BigChina
Newbie Joined: 11 Jul 2014 Online Status: Offline Posts: 28 |
Topic: dust removal on Vanquisher II Posted: 17 Nov 2014 at 12:19pm |
Hi, i have had my vanquisher II for about half a year now, and i have loved the machine so much!! However, the front panel (with the two fans) is getting a bit dusty. I was wondering if the grill in the front of the dust collector is remove able to clean it, or if there is another way to get rid of the dust.
Quote Reply Posted: 17 Nov 2014 at 12:34pm |
Here's a link where Snaike, another one of us, did a great job explaining it, with pics.
http://www.digitalstormonline.com/forums/removing-dust-from-the-mesh-filter-on-vanquish-tidf22849/ Hope this helps. |
Quote Reply Posted: 20 Nov 2014 at 12:32am |
Thanks bprat... Haven't been around lately to help. To BigChina... you can also, once you get the front fascia off, run it under water because those filters are glued to the plastic.
Also, be sure to get in there with some canned air to get the fans in the machine and on the cards. Clean what you can and that little Vanquish will keep you in the games for years.
