Dual monitor help!Post Date: 2014-06-10 |
TehGoat
Newbie Joined: 10 Jun 2014 Online Status: Offline Posts: 2 |
Topic: Dual monitor help! Posted: 10 Jun 2014 at 3:35pm |
My Digital Storm Desktop came with a small, black converter, i think it made the the cord that i plug into my tower DVI can someone link me or tell me what to search for... Or if Digital storm sells them alone? I need it, i would prefer the exact one that the PC comes with thanks!
Quote Reply Posted: 10 Jun 2014 at 4:07pm |
i think that black converter is for the vga cable which you don't need
Quote Reply Posted: 10 Jun 2014 at 5:50pm |
I believe you are talking about a DVI to VGA convertor. You can buy them from anywhere but it is only necessary for older monitors. If you have anything that is modern it should have HDMI or DVI that you can use.
TehGoat
Quote Reply Posted: 10 Jun 2014 at 6:25pm |
My monitors have HDMI but the inputslot on my tower is much smaller than the usual hdmi
Quote Reply Posted: 10 Jun 2014 at 10:39pm |
That's odd, all graphics card usually feature a full HDMI plug. Are you able to take a picture? |
Quote Reply Posted: 11 Jun 2014 at 3:08am |
Are you using the video card ports located below the rear fan and running horizontal or the motherboard ports next to the fan and next to the USB ports ? The video card ports , what you need to use, might have black plastic caps covering them.
Let us know how you make out. |
TFD_Industries
Newbie Joined: 11 Jun 2014 Online Status: Offline Posts: 3 |
Quote Reply Posted: 11 Jun 2014 at 7:31pm |
Might be a mini HDMI port which you will need to buy a mini HDMI to HDMI cable/converter.
