Dual 680's = TITAN?
Post Date: 2013-08-12
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Topic: Dual 680's = TITAN?
    Posted: 12 Aug 2013 at 6:08pm
3500
speed and quiet
gaming
None
Saved Ticket #: [Please Type Here]
[Please Type Here]
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Aug 2013 at 6:29am
Dual, sli gtx 680 beat Titan by about 20% in gaming.
Gnicky View Drop Down
  Quote Gnicky Quote  Post ReplyReply bullet Posted: 13 Aug 2013 at 6:41am
http://www.anandtech.com/bench/product/766?vs=764
bprat22 is (of course) correct - anandtech happens to have that exact comparison
Tio View Drop Down
  Quote Tio Quote  Post ReplyReply bullet Posted: 13 Aug 2013 at 7:26am
Is exactly what I currently have (4GB -w- Back plate version's) and is very capable.I currently have it running Dual Monitors of which 1 is a Dell U3014 2560x1600 (main) and an Asus 27" 1920x1080 (secondary) and it handles both fantastically. waiting on the new system (3x Titain's) to arrive so I can add more monitors Possibly 2 more of the Dell's) as well as a Wacom Cintiq 24HD. If you can fit it into your build the GTX780's in SLI would offer you so much more as they are based on the Keplar GK110 chipset as apposed to the previous version GK104 found in the 680's, 770's and 760's. Also the 700 series benefits from the newer bio's architecture and are more efficient and run cooler than their predecessor's.
Hailstorm II
Intel 3970K
Corsair 1200i
32gig Corsair Dominator Platinum
Samsung 512gif 840 Pro SSD
4tb Western Digital Black HD
Blue-Ray and DVD Burn/Player
3xSLI EVGA GTX Titan Hydro Copper Video
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 02 Sep 2013 at 7:26am
One other dumb question. The Titan 6GB...is this like having three 2gb video cards?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Sep 2013 at 7:32am
Not a dumb question... actually a good one a lot might need to know.
If you mean 3x 2gb cards in tri-sli, bridged together, then no.   Video cards in sli or tri-sli only have the vram of a single card.  Vram doesn't stack.. So, a tri-sli 2gb cards is still 2gb vram.  Titan, being a single gpu does have 6gb .
Hope this helps.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 02 Sep 2013 at 7:46am
Ok...so thats 2 cards in 1 or 3?
fstcvc View Drop Down
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 02 Sep 2013 at 8:16am
VRAM doesn't add up. It's whatever 1 card has as each card has the same info stored in it. If you have 1, 2, 3 or 4 cards and each card has 2GB VRAM, then you have 2GB VRAM. The Titan is a single GPU with 6GB of VRAM so you get 6GB of VRAM no matter how many of them you are running in SLI mode.
HailStorm II
i7 4770K @ 4.5GHz
Asus Maximus VI Extreme
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Sep 2013 at 8:20am
If you're looking at it from a strictly vram perspective, then the Titan has 3x the vram of a, for example, gtx 770 2gb card.   But from a gaming performance side of it, a sli, 2x gtx 770 at 2Gb vram will give better gaming on most single monitors.  sli, gtx 780 with its 3gb per card is even better.  Vram is important but tells only a small part of the story.
A 6gb vram Titan card isn't equal in gaming to two 780's at 3gb each.  Not even close.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 02 Sep 2013 at 9:27am
Ok...I got that now. Thanks! Its best to get 2 780's!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Sep 2013 at 8:54pm
For games that don't utilize sli correctly, then the titan beats anything, but for games that do sli correctly, titan gets beat by sli.
So what we need is based on what we want to do and if that task supports sli or not, but also do I have use for sli or not too. For example sli 780 or single titan for a 20" monitor is pure waste.
IMHO instead of asking sli or titan, tell us your monitor's native res and what kinds of games you want to max out on that monitor and then we can tell you exactly what kind of power you need and if you even have use for sli.
Edited by DST4ME - 02 Sep 2013 at 8:55pm
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 03 Sep 2013 at 3:44am
Acer 27" monitor / Call of duty 3 / Battllfield 3 / Crysis 3
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Sep 2013 at 3:58am
whats the native res?
for around 1900 x 1200 sli 780/680 should do the trick, I think crysis is the main one that needs it to be above 60 fps.
Edited by DST4ME - 03 Sep 2013 at 3:59am
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 03 Sep 2013 at 4:12pm
This is the monitor I am looking at
Acer Black 27'' 6ms (GTG) Widescreen LED Monitor
I really really really want to get dual 780's! If it's not possible..the single 690 or titan will do.
btw...I have a dell 22" (bought it in 2009...this be ok?)
Edited by Clay - 03 Sep 2013 at 5:42pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Sep 2013 at 10:29pm
The "6ms" response time is bs. never pay attention to that.
what is the model of the 27"?
You are probably better off with sli 780.
Edited by DST4ME - 04 Sep 2013 at 11:40pm
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 05 Sep 2013 at 3:47am
27EA33V
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Sep 2013 at 3:54am
if you are talking about this one
then ya sli 780 will give you 60fps with highest settings in games like bf3 and crysis.
but that is an lg monitor and not acer, which tho I'm not an lg fan, lg is better than acer.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 05 Sep 2013 at 3:47pm
Yes, that is the one....thank you sir. Appreciate all the help guys. I am almost there!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Sep 2013 at 4:00pm
Our pleasure and good luck
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 14 Sep 2013 at 4:13am
Ok..this really sucks! just found out my wife bought another laptop from DS, which took away the "extra" i was going to save for a gaming rig! So, I had to go locally to build, at least i am still apart of the DS family! It's not much, but it will do!
Edited by Clay - 14 Sep 2013 at 5:49am
I7 13700KF 5.4hz
ASUS Prime z790 MoBo
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
27" ASUS Monitor 144hz
Razer Ornata Chroma Keyboard
Razer Basilisk V2 Mouse
Nari Ultimate Headset
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Sep 2013 at 6:10am
As long as you're happy, then its all good.   Awesome
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 14 Sep 2013 at 6:12am
Bprat! We need to do some gamin bud! What games you play?
I7 13700KF 5.4hz
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Sep 2013 at 6:18am
Big%20Smile  I don't do much on-line.  Mostly Civ 5, Elder Scrolls, Far Cry 3, etc.  But, thanks for the invite.  Awesome
Might check out BF 4 when it gets released.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 14 Sep 2013 at 6:35am
I have it pre ordered...got COD 3 / BF3 just to get me back into shape!
I7 13700KF 5.4hz
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 03 Oct 2013 at 6:38pm
Well got the ASUS VS278 27" (1ms)
I7 13700KF 5.4hz
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 09 Jul 2014 at 8:05pm
I have an opportunity to buy a 690 now. my main concern is SLI mode for COD: Ghost. Have they fixed that issues as of yet?
I just like the 690 because its a bit faster that the titan?
any thought?
I7 13700KF 5.4hz
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
Nav View Drop Down
Digital Storm Employee
  Quote Nav Quote  Post ReplyReply bullet Posted: 09 Jul 2014 at 9:41pm
Personally, I wouldn't go with the 690. You'll have VRAM issues down the road. Stick with your GTX 780 (I'm going by your signature).
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Jul 2014 at 3:22am
Agreed.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 10 Jul 2014 at 3:41am
you guys are funny... this was posted back in Aug lol
BUT
I was "thinking" about the 690 just because warranty will allow me an upgrade or an equivalent part. I'm trying to talk them into getting me the Titan (the one that came out about a year ago).
I have another post on this somewhere that bprat commented on :-)
Edited by Clay - 10 Jul 2014 at 3:44am
I7 13700KF 5.4hz
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 10 Jul 2014 at 6:57am
BUT
August? Guess the forums had a d'oh! moment.
"Posted: Yesterday at 8:05pm"
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 10 Jul 2014 at 7:11am
made in August, last comment was in October...lol
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
