DSO Expedition Review
Post Date: 2010-12-25
Page  123 5>
MagiK View Drop Down
  Quote MagiK Quote  Post ReplyReply bullet Topic: DSO Expedition Review
    Posted: 25 Dec 2010 at 12:56pm
This thread will be for pictures and benchmarks and screen caps, todays postings will be the pics from when I received the System on 12/24/2010
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 12:59pm
size is 31w x 31d x 34h  in inches
Edited by MagiK - 25 Dec 2010 at 1:00pm
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:02pm
Well packed with expanding foam
lots of expanding foam
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:04pm
Unit is 18inx18inx18in and the package came in at about 70 pounds
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:05pm
Accessories come in two boxes
Edited by MagiK - 25 Dec 2010 at 1:05pm
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:07pm
Manuals and left over parts
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:10pm
Disks plus one on the back side for the SSD
The front, Right hand 5.25" bay is basicly useless as the TEC unit encased in foam is right behind it.  The left Bay cannot be removed because the LCD that displays the temp of the chilled liquid is hot glued to the left side of the bay.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:12pm
Very Nice Magik Congrats
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:14pm
From the left hand side of the case you see the Main power supply and the video cards...note the massive cooler panel.  Offending glue job on the LCD to the lower right prevents you from removing that bay to access the HDD's that are just on the other side of the Power Supply.
HDD bay is right behind the lower 2 fans...but you cannot access it from the left side of this picture as there is a ton of wiring and supports in the way
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:16pm
Well that is all the pictures for now, more later when I have had time to actually use the system a bit  LOL  I will say it boots so fast my old computer is still doing BIOS and pre-boot stuff.  Running Unengine's Heaven DX11 test right now.  L8R peeeps.  Merry Christmas.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:18pm
Merry Christmas Magik, don't forget to tell us load temps and etc
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:35pm
@MagiK,
Wow! Your system looks great! It's even better once you show off your temps and benchmarks!
In regards to the LCD temp screen, you could remove the glue (comes of easily) to mount the LCD to a difference place, but we'll work on trying to place it on the drive bays for future builds. Thank you for helping us improve our latest products for our customers.
(P.S. this thread isn't suppose to be in the 'Cofiguration Discussion' area so I'm going to move it to the General Discussion one. After you've posted your benchmarks, etc that you wanted to add, then I'll move it to 'Customer Reviews').
Edited by Alex - 25 Dec 2010 at 1:35pm
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:41pm
Okie doke, Didnt know where to put it once I figured out I couldnt put it in the reviews  Hahaha  Heaven ran at an average of 44FPS with all the menu selections as high as they would go at 2560x1600 with GPU temps up to 55 or so.....more acureate stuff will have to wait for a bit
justin.kerr View Drop Down
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 1:43pm
can't wait for some results!
HDDs can be mounted anywhere there is a fan, so looks like there would be a few other options.Big%20Smile  I mount mine to the underside of the horizontal mobo tray, better wire management.
am I correct, in saying 9 fans intaking, 2 exhausting??
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:01pm
11 intake a triple rad a double rad and a lone fan, each of the rad fans is a dual push pull config, exhaust is a pushpull single rad and 4 single fans
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:18pm
Make a list of what you want me to run and want to see....Here is what I have so far all at idle:
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:34pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:40pm
Whats the deal with the vcore? not showing up
lol is that the DS oc on gpu?
can we get a shot of HWMonitor wide open showing everything and for more accurate temps on cpu please show RealTemp please run the gt version from its folder since you have a 6 core.
TIA
Edited by DST4ME - 25 Dec 2010 at 2:42pm
Scorp View Drop Down
  Quote Scorp Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:47pm
Would have loved to see more LC tubing visible from the large window panel side... BUT IT LOOKS FREAKIN AWESOME!!!
Unigine seems a little low...I think... Not sure though... will have to check my rigs just to confirm...(currently in Italy so meh >.< )
@Alex, With my rig, say... I decide in a few months to a year that I want that sub-Zero Awesomeness, would it be possible to send it back to DSO for an upgrade? :D
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:50pm
If your case has room for it, I don't see why you can't send it back
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:52pm
CPUz in mem tab.
furmark with post proc, xtreme mode.
3dmark vantage or 3d 11.
Linx, max mem, with realtemp for temp Big%20Smile
with post proc, you will see the waves in the flames like this.
Edited by justin.kerr - 25 Dec 2010 at 3:03pm
  Quote Scorp Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 2:56pm
http://digitalstormonline.com/forums/forum_posts.asp?TID=12452
Has it space? >.<
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:05pm
The TEC Power supply is a second unit, in my case it is a Corsair HX1000
You can also have the TEC powered by an external power brick,  the TEC unit itself is encased in a 3x3x3 inch block of expanding foam  so it takes at least that much free room in the case,  and it is on a separate LC loop and reservoir.
Keep in mind this is exactly how the system performs out of the box, I havent tweaked or changed anything.
Edited by MagiK - 25 Dec 2010 at 3:09pm
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:16pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:24pm
can you post a pic like the one I did?
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:24pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:26pm
now just need Linx with realtemp. LOLBig%20Smile
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:30pm
Not sure how to capture that image, there were lots of heat ripples on the screen
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:45pm
print scrn, or MSI afterburner. Big%20Smile
looks very promising, can't wait to see the Linx results, and temps.  I can see a few tweaks to improve performance, but just stuff I would do to get the most, the way it is it is powerful. Strong
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:49pm
Once I get all the screens Id be happy to entertain any suggested changes  Hahaha
I just want to get the baselines out of the way.
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 3:50pm
Do you have a download link for Linx?  I found too much crap to wade through at the moment.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 4:04pm
linX 0.6.4
Edited by DST4ME - 25 Dec 2010 at 4:04pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 4:08pm
Originally posted by DST4ME
linX 0.6.4
not the correct one the 6 core.
dman noob.. LOL  merry fn'ing Christmas
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 4:24pm
Just as a side note, the cores are going below -16'C on IDLE. It's just that the software won't show a lower temp
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Dec 2010 at 4:27pm
Sure!
 Post Reply Post Reply Page  123 5>
This page was generated in 0.203125 seconds.
