DS Liquid Cooling - PartsPost Date: 2014-03-14 |
gloryofthesky
Groupie Joined: 07 Jun 2013 Online Status: Offline Posts: 152 |
Topic: DS Liquid Cooling - Parts Posted: 14 Mar 2014 at 6:16pm |
Hi, i own a digital storm HailStorm II level 3, I actually did not put water cooling on it due to because I already owned a previous water cooling system from corsair.
Im looking to upgrade, and I was wondering what are the parts for a custom water loop? |
fstcvc
Quote Reply Posted: 14 Mar 2014 at 10:58pm |
Main parts of a custom water cooling system are reservoir, pump, radiator, fans (to go on the radiator), water blocks for the components you want to cool and hosing/fittings to connect everything together... You can also multiples of the radiators, reservoirs & pumps depending on the complexity of your setup.
Here are some kits made by XSPC (minus the hoses & fittings) - these kits have the pumps attached to the reservoirs. There are many more kits available or you can buy the parts all individually. Hope this helps... Edited by fstcvc - 14 Mar 2014 at 11:00pm |
HailStorm II
retirednavysnipe
Senior Member Joined: 06 Apr 2012 Online Status: Offline Posts: 606 |
Quote Reply Posted: 15 Mar 2014 at 6:09am |
Do a search on the web for water cooling. You will find companies that will sell you every thing you need in a complete set. I priced out a single loop 240 mm fan/radiator cooling system for about $250.
They are not that expensive just gotta do some diligent research. |
Hailstorm Black Ops
I7 3930K 4.5GHZ 16GB 1600MHZ ram 2 x GTX 680 120 GB SSD, 1 TB hardrive Fully liquid cooled CPU, GPU and chipset. |
Quote Reply Posted: 15 Mar 2014 at 11:32am |
Frozen CPU carries a wide variety of components for custom and closed loop systems.
