Driver Conflict?Post Date: 2014-11-07 |
Oxon
Newbie Joined: 09 Jun 2012 Online Status: Offline Posts: 25 |
Topic: Driver Conflict? Posted: 07 Nov 2014 at 10:13am |
I have the following issue: all nVidia drivers after 335.23 install fine, BUT cause
Windows to freeze on the startup logo the next time I boot. So I have been stuck with a video driver that's about 6 months old now.
I have tried clean installs of the drivers. I have tried resetting all overclock to stock... I don't think it is a problem with my video cards (2 x GTX 680 in SLI) because they seem to work perfectly with the older drivers. If they were going bad, I'd expect to see some problem manifest itself with the older driver. The only hardware change I made around the time this started was adding a LSI MegaRAID 9260-4i. But it all works fine with 335.23 and prior nVidia drivers. Any thoughts on what the problem might be, and/or how to resolve it? I want to keep this system for a while, so not being able to update video drivers will be a major bummer. And if I want to update the graphics cards down the road, I'll definitely be upset if I can't update the driver. Thanks for any thoughts / advice! Relevant hardware and OS: 2 x GTX 680 in SLI ASUS Rampage IV Extreme (BIOS fully updated) Windows 7 x64 LSI MegaRAID 9260-4i Thanks for any info / help! |
Quote Reply Posted: 07 Nov 2014 at 1:12pm |
Hi Oxon.... For the clean driver install did you do it with the clean option with the download,or use CCLEANER , DriverCleaner, etc to manually delete the files? I haven't had to use either in a couple of years, the driver install being just fine, but it might be necessary here.
It's possible one of your cards isn't playing nice with newer drivers. You could unplug one card at a time and see if it works with the newer drivers. Not common but possible. If all else fails, just use what driver works. The newer ones help some but not necessary. Good luck. If by chance it is a card you obviously don't want to leave it on one card, but it'll tell you what's up. Edited by bprat22 - 07 Nov 2014 at 1:32pm |
