This review has been a long time coming. I ordered my system in back in May but waited until I really got to know the system and have some experience with it before posting a review.
The specifications:
Chassis: 942 HAF X
Trim Accents: Paint Chassis Vents and Grills (Blue)
Processor: Intel Core i7 2600K 3.40GHz
Motherboard: ASUS Maximus IV Extreme
System Memory: 8GB DDR3 1600MHz Digital Storm Certified
Power Supply: 1000W Digital Storm Certified
Hard Drive Set 1: Operating System 1x(120GB Intel SSD 510 Series)
Optical Drive 1: DVD-R/RW/CD-R/RW(DVD Writer 24x / CD Writer 48x)
Internet Access: High Speed Networ Port
Video Cards: 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB)
Extreme Cooling: H20: Stage 3
H20 Tube Color: White Tubing (UV Reactive)
Chassis Airflow: Upgrade Chassis with LED Performance Fans (Blue)
Internal Lighting: UV
CPU Boost: Stage 1: Overclock the processor between 4.0 and 4.5GHz
Windows OS: Windows 7 Home Premium
MISC: add blue led 200mm fan on front
MISC: add extra blue internal light
I ordered my system on 4/30/2011 (a Saturday). After a few problems with getting DSO my money (stupid bank, NOT DSO's fault) it was started on May third. While being built I was frequently emailed and contacted by DSO regarding my system. I was notified that the game I had ordered wasn't available nor was the antivirus software. I was refunded for these and they did not delay my system.
Build Time
Stage 1: 5/03
Stage 2: 5/04
Stage 3: 5/04
Stage 4: 5/06
Stage 5: 5/09
Stage 6: 5/13
Stage 7: 5/13
After eagerly stalking it journey across the country (FedEx seamed to move at a glacial pace with such an awesome piece of hardware) it arrived on 5/19. Since FedEx couldn't deliver at my house I had to pick up my new beast and load her into the car (she barely fit). Hauling that 70lb box up the stairs was a challenge too!
Unboxing the system was a blast. It was neatly and professionally packaged with all the extra components, sweet t-shirt and system binder in neat boxes. The system its self was nestled nicely in the stout box.
Review
My system is mind-blowingly awesome! It is impossible to overstate the craftsmanship and power are in this system. DSO did a heck of a job building it, the cable management on the back is a work of art, and the whole system just looks AMAZING! In terms of performance the only things that even makes her sweat are benchmarks; real life applications and games are buttery smooth and more pretty than I could have imagined.
The system has been remarkably stable, I had a weird problem getting her to boot about a month ago but after calling DSO and talking to their VERY helpful, friendly and knowledgeable technician the issue was resolved. At the time DSO was very busy but the tech was willing to help me over the weekend from his home. I CANT EXPRESS HOW AWESOME IT IS TO KNOW A COMPANY CARES!
With regards to my build, there are a few small things I would change now. I would have purchased a 320 series SSD instead of a 510. maybe also got a WD 1TB drive. The main thing i would have changed is using standard 570's instead of EVGA ones. the main reason for this is for compatibility with water blocks.
Since receiving the system I have done some modifications to it, added hard drives ect (now have a 510, 320 and 1TB WD). The most major change was when i tried to watercool the GPU's. after ordering all the components i discovered whilst trying to mount a water block that the EVGA cards dont match the standard NVIDIA ones and so the water block wouldn't fit. since I couldn't return the blocks i ended up having a machine shop cut into the blocks so they would fit and resealing the hole. All of this was my own fault and I should have checked before ordering the system or better yet just have DSO do it. anyway, now my system is running great and cooler than ever.
PICTURES!
all of these were taken when I first got the system, so with out my modifications.
