Doable? Apollo BuildPost Date: 2015-04-30 |
Page 123> |
GamerGalKim
Newbie Joined: 29 Apr 2015 Online Status: Offline Posts: 55 |
Topic: Doable? Apollo Build Posted: 30 Apr 2015 at 10:34am |
[2500] Expectations: [Performance and Aesthetically pleasing] Usage: [Gaming and multitasking] Special Needs: [Not sure] Specifications: [Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE Z97X-SLI (Intel Z97 Chipset) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX750M Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Seagate) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless USB 802.11n (Supports 802.11n/g/b) <br><strong></strong> Graphics Card(s): 1x NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Remote Controlled LED Lighting System (Multiple color options and lighting effects) <br><strong></strong> Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) ] So...was wondering if I can request something special? Like purple fans? http://www.newegg.com/Product/Product.aspx?Item=N82E16835181053 |
Pacesetter
Quote Reply Posted: 30 Apr 2015 at 10:53am |
Looks like a nice solid build. The fan on the water cooler is what it is but if you call and talk to sales they can give you the options on case fans. They may be able to get the purple on a special order. That white case with purple fans would be sweet looking. |
Quote Reply Posted: 30 Apr 2015 at 10:55am |
Hi Kim.... Welcome to the config section.
That is a very good, solid build. I would, if the budget allows a little more, change the 850 EVO to the 256gb 850 Pro. A better drive. Also, change the Seagate HDD to the Western Digital Black, also a better drive with longer warranty. You can special order pretty much anything here at DS. Just talk to sales and they'll quote you the price, which does include a special order price. Special orders aren't covered under warranty last I heard. Just the part, not the rig. Good Luck. |
GamerGalKim
Quote Reply Posted: 30 Apr 2015 at 10:56am |
Thanks Pace!
I hope I can get purple fans. Will name it, "Purple Passion" :D |
GamerGalKim
Quote Reply Posted: 30 Apr 2015 at 10:57am |
Thank you. Will try what you recommended. As long as it remains at 2500, that will be what I do. |
Quote Reply Posted: 30 Apr 2015 at 1:27pm |
Hi Kim,
Glad to see you took my suggestion and submitted a system. Your build is good and probably the best you can do with your budget on a custom build. If you can stretch your budget then besides the changes suggested by bprat22, you could get the 750 SuperNova PS. DS does offer a LED Fan option but they only have Red, Green and Blue. The purple would be special order. You could order the stander fans with no LEDs and change them out yourself. It is not hard to change fans and you could get the purple fans. Frank |
GamerGalKim
Quote Reply Posted: 01 May 2015 at 4:11am |
Hi Frank! Can't stretch my budget, but will do some tweaking in a bit to see if I can make some adjustments.
I will try that with the fans myself. Have to say tho, I have never done anything inside the puter before, so...I will be a lost ball in tall grass. Can the internal lights be done easily as well? Kim |
Quote Reply Posted: 01 May 2015 at 9:36am |
Hi Kim,
Changing fans is very easy even for a beginner. All you have to do is remove the old fan and mount the new fan. When you remove the old fan follow the cord back to the motherboard and detach the connector. Plug the new fan into the same header/connector. You might have to cut some ties to get the old cable out. Just put ties back where you found them after you run the new cable. You will find that some fans have metal screws and some have a plastic or rubber screw/connector. You can do a Google search for "How to install a computer fan." The videos are a great help. You can also search "How to replace a computer fan." Frank Edited by FrankW - 01 May 2015 at 9:38am |
GamerGalKim
Quote Reply Posted: 01 May 2015 at 12:08pm |
Frank, I am worried about static. Should I be? Do I need to wear one of those bracelet thingies?
Kim |
GamerGalKim
Quote Reply Posted: 01 May 2015 at 1:16pm |
Updated the build...
Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE Z97X-SLI (Intel Z97 Chipset) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W EVGA SuperNOVA <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x Storage (1TB Western Digital - Black Edition) <br><strong></strong> Storage Set 2: 1x SSD (256GB Samsung 850 PRO) <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless USB 802.11n (Supports 802.11n/g/b) <br><strong></strong> Graphics Card(s): 1x NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Remote Controlled LED Lighting System (Multiple color options and lighting effects) <br><strong></strong> Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Look better? It is 55 bucks over budget. Does the up to $200 off, which I would receive $75, come after this price? |
Quote Reply Posted: 02 May 2015 at 1:56am |
Hi Kim, When I'm poking around in my machine (cleaning, tightening, reseating, curious, etc) I'm on hardwood/linoleum where there is much less chance of static buildup. So, I'm generally not worried about it. If you're standing on carpet there is a much greater chance. If you are worried about it, stores like Office Depot carry small straps for $5 or so. Small price for peace of mind. Hope this helps. |
Quote Reply Posted: 02 May 2015 at 3:27am |
Hi Kim........ That a solid build. Nice changes you made. I would swap the drives so the SSD is drive #1 so primary drive,SSD, has the OS on it. DS will probably do it anyways, but why take chances.
I use a static strap whenever I poke around with the rig, or any electronics. Mine is all frayed. Have had it for 20 years. Time for a new one. The wrist strap has a clip to hook to metal to keep static from frying anything. I believe the $75 is taken off at checkout. Might pay for the ground shipping. No tax applied unless you live in Calif. last I heard. Edited by bprat22 - 02 May 2015 at 3:31am |
Quote Reply Posted: 02 May 2015 at 5:53am |
Hi Kim,
I think using an ESD strap is a good idea for anyone working on the inside of the computer. Some users connect the strap to a bare metal part/screw on the back of the computer. This should keep you and the computer case at the same potential. The problem is you may forget to touch the case after you walked some place and returned to the computer. You may have picked up a static charge while moving about the area. If the computer is plugged into an outlet then the case will be grounded and so will your strap. You make sure the power switch is turned off. I never liked to work on my computer with the cord plugged in. I prefer to unplug the computer and connect my ground strap to the ground of an outlet. I touch the bare metal back plate of the case every so often to make sure it is at the same ground potential that I am. If you touch other metal parts of the case you need to make sure they are connected to the back plate of the computer. You have a great build and will give you years of service. Frank Edited by FrankW - 02 May 2015 at 2:58pm |
GamerGalKim
Quote Reply Posted: 02 May 2015 at 9:29am |
Hi guys! I have carpet, so the strap might be a valuable purchase.
So, I will address the primary drive when I make the call to order the rig. I think DS will get tired of me and my questions. :P Did not realize there would not be tax. That is a huge bonus to me. I was figuring that in. This might be doable before my estimated date...my birthday in June. Fingers crossed. |
Quote Reply Posted: 02 May 2015 at 10:25am |
Not in California, no 9.5% sales tax.. If I were to budget $2500, I'd pay $237.50 in tax. On the flip side, I'm close enough to DS to not pay a shipping charge.
So, at least I have that, which is nice. |
Pacesetter
Quote Reply Posted: 02 May 2015 at 2:28pm |
Hi Kim,
This is some advise I gave to my daughters when it comes to their computers and changing things out. Be barefooted or wear rubber soled shoes. Use a wrist strap but also always touch the frame before reaching inside. When using tools (screwdriver etc) touch the tool to the frame first. Use a flashlight! You want to see everything and never guess. If something fights you or is hard (installing ram, plugs etc) something is wrong. Look closely and make sure you are doing it right, have slots aligned etc. Don't wear silk undies, they make static. Static is not static - it's generates itself, builds on it's own and will zap you at it's convenience and cannot be anticipated. |
Quote Reply Posted: 03 May 2015 at 12:09am |
Wow, I learned something today. Next time, I clean the computer in the buff! |
Pacesetter
Quote Reply Posted: 03 May 2015 at 3:59am |
Quote Reply Posted: 03 May 2015 at 4:50am |
Hey! I was assured those photo's were destroyed!
Unless /gasp/ they're new ones and you know where I live?!?!? |
GamerGalKim
Quote Reply Posted: 03 May 2015 at 5:26am |
Roflmao!
Thanks guys for the advice and the laughs! |
GamerGalKim
Quote Reply Posted: 04 May 2015 at 9:57am |
Question.
How many fans total are in the Apollo? I talked with Tammy earlier, but am a little confused about the total. I want to say 3 140mm and 3 120mm? |
Quote Reply Posted: 04 May 2015 at 10:22am |
Hi Kim,
The Apollo is the Corsair 760T case in the Graphite series. You can go to the Corsair site and see all the features of the case. This is what is listed for the fans. Radiator and fan compatibility: Top: 3 x 120mm or 2 x 140mm. Front: 2 x 140mm or 2 x 120mm (2 x 140mm LED included). Bottom: 1 x 120mm. Rear: 1 x 140mm or 120mm (140mm included Hope that answers your questions. Frank |
GamerGalKim
Quote Reply Posted: 04 May 2015 at 10:33am |
Thanks Frank. So I would need to order, for my purple fans, 5 140mm and 1 120mm? Total of 6 fans?
For my internal lighting, would I order a dual 12" light kit or 2 of those? From the case it looks like one. |
Quote Reply Posted: 04 May 2015 at 11:32am |
Hi Kim,
The H20 120 cooler you have ordered uses two 120mm fans. You only need to light the one fan that is on the interior side of the Rad. But it needs to be a 120mm. So you will need two 140mm fans for the front. Two 140mm fans for the top. One 120mm fan for the Rad. With only one GPU you don't need the bottom fan. I don't know if anyone mentioned it but you can buy your fans and ship them to DS and they will install them for a fee. I don't know what that fee would be. If you get the Corsair Fans DS might order them for you. I would talk to your sales person and see what they would charge you. Frank Edited by FrankW - 04 May 2015 at 11:33am |
GamerGalKim
Quote Reply Posted: 04 May 2015 at 11:59am |
Thank you again, Frank.
One last question though about the internal lighting. To adhere it, would I use the sticky velco provided? I am concerned about heat melting that. Would you recommend a heat resistant glue that might be better? Also, to comment on your last statement, I am not sure, but I believe any special ordering for the aesthetics would increase my grand total past my budget. I honestly would prefer DS to do it, but I believe if I am capable, and it is cheaper, I can do it myself. |
Quote Reply Posted: 04 May 2015 at 3:11pm |
Hi Kim,
I am not a light guy so don't have any knowledge about them. Maybe someone who has the Apollo with lights can comment. I understand budget. Frank |
Quote Reply Posted: 04 May 2015 at 4:02pm |
The LED bar in my Vanquish is simply held by two double-sided plastic clamps. Press and hold type.
Clay
Quote Reply Posted: 04 May 2015 at 6:41pm |
Very nice looking Rig!!
I7 13700KF 5.4hz
GamerGalKim
Quote Reply Posted: 08 May 2015 at 4:22am |
Today is the day that I can order. I am very excited!!
As for the internal lighting, I decided I'd go with the velcro provided and hope it stays. I am going to order the 12" light kit. As far as I know, I just need one? |
Quote Reply Posted: 08 May 2015 at 5:26am |
should be just the one...
Congrats on the purchase today! Remember to get the Verified Customer tag, your email for the forums and the email you order have to match exactly (case sensitive!) We'll be looking for it! |
GamerGalKim
Quote Reply Posted: 08 May 2015 at 7:18am |
Thanks!
So nervous the Spring deal will be over before I can make the call. :/ |
GamerGalKim
Quote Reply Posted: 08 May 2015 at 9:28am |
<--- Oh look!
Pacesetter
Quote Reply Posted: 08 May 2015 at 11:14am |
Congrats and welcome to the family! |
hoserator
DS Veteran We don't need no stinking "Avatars" ! Joined: 08 Oct 2014 Online Status: Offline Posts: 7942 |
Quote Reply Posted: 08 May 2015 at 11:24am |
+1
Now the waiting starts |
Quote Reply Posted: 08 May 2015 at 1:14pm |
Hi Kim,
Glad to see you put in your order. Welcome to the Digital Storm Family. Frank |
Post Reply | Page 123> |
