Custom Configuration QuestionPost Date: 2014-04-16 |
FattyBluntface
Newbie Joined: 10 Apr 2014 Online Status: Offline Posts: 13 |
Topic: Custom Configuration Question Posted: 16 Apr 2014 at 3:34pm |
How do I make changes to the Vanquish II level 2? I want to change the processor. I've seen other custom configurations of PCs on here. Thanks for the help.
Quote Reply Posted: 16 Apr 2014 at 3:34pm |
All the vanquishes are pre-built and non-changeable
FattyBluntface
Quote Reply Posted: 16 Apr 2014 at 3:38pm |
Why is the configuration of this Vanquish customized:
digitalstormonline . com/ configurator.asp?id=871700 Thanks for the reply. |
Quote Reply Posted: 16 Apr 2014 at 3:42pm |
That link you posted was for the Vanquish 1 which is no longer available |
FattyBluntface
Quote Reply Posted: 16 Apr 2014 at 3:50pm |
It says it's Vanquish II, though. http://www.digitalstormonline.com/configurator.asp?id=871700
Quote Reply Posted: 16 Apr 2014 at 3:53pm |
I realize that but its got the Vanquish 1 case listed as the chassis model and since the vanquish 1 link that the guy posted back in 2013 doesn't work it will show the vanquish 2 case instead Edited by ArkansasWoman777 - 16 Apr 2014 at 3:54pm |
FattyBluntface
Quote Reply Posted: 16 Apr 2014 at 3:58pm |
Oh, OK. Much thanks.
Quote Reply Posted: 16 Apr 2014 at 3:59pm |
You're welcome |
