Corsair 800D Question
Post Date: 2012-06-03
tkicepick View Drop Down
  Quote tkicepick Quote  Post ReplyReply bullet Topic: Corsair 800D Question
    Posted: 03 Jun 2012 at 10:54am
Hi everyone
I'm thinking of replacing my rig within about a year, and I'm eyeing the Obsidian 800D.
Having gone with air cooling so far (current CM HAF 932 owner), I am reluctant to skimp on airflow, even if I move to a closed or custom water loop.
I was wondering how much space their might be to install 1 or more 200mm or 230mm fan(s) in this sexy black box.
It looks like there may be space on the bottom at least, but I'm not sure.
Definitely considering buying from DS on this next go-round.
Thanks for any and all input!
-icepick
"PS im sure my job as a helicopter pilot gives me plenty of coodination for that sort of thing" - Tomcat
Tidgxor View Drop Down
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 03 Jun 2012 at 11:35am
200 or 230? I don't think that would be possible without case mods. I don't own the 800D so take that with a grain of salt, though I've never *personally* seen a 200 or 230 in one, and I've seen quite a few of those cases in person.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Jun 2012 at 12:43pm
Yep, the 800D has cutouts for 4 more 120mm fans , 3 of them on top..     Like Tidxgor said,  with the right tools ( saws, drills, etc.) I'm sure it can be done.
  Quote Alex Quote  Post ReplyReply bullet Posted: 03 Jun 2012 at 3:10pm
The 800D would need some serious modding to do this, there are other cases now that Corsair makes which have larger fans if you need them?
  Quote FrankW Quote  Post ReplyReply bullet Posted: 04 Jun 2012 at 8:28am
If you like your 932 case you will love the HAF-X case. For air cooling I think you can do much better than the 800D.
josephlee View Drop Down
  Quote josephlee Quote  Post ReplyReply bullet Posted: 05 Jun 2012 at 4:48pm
Yeah, what Frank said. If you are looking for air cooling, 800D wouldn't be my first option
