CONFIGURATION ADVICE
Post Date: 2012-07-30
RICK2197 View Drop Down
  Quote RICK2197 Quote  Post ReplyReply bullet Topic: CONFIGURATION ADVICE
    Posted: 30 Jul 2012 at 1:59pm
I'm looking for some input on the configuration shown below. I want a killer gaming machine that can be used for home office work too. I currently own an Alienware that is 3 years old. My budget is rather high based on this configuration. After reading some of the other posts I may be guilty of a little overkill and would appreciate any input on where I'm wasting money or making a good investment. I currently use 2 monitors but have no interest in 3D.
Ticket Number: 713301
Total Price with Instant Savings: $5,316.00
Processor: Intel Core i7 Extreme Edition 3960X 3.3GHz (Six-Core) (Extreme Performance)
System Memory: 16GB DDR3 2133MHz Corsair Dominator GT with DHX (High-Performance)
Expansion Bay: Dual Solid State Hard Drive Hot Swap Bay
Video Card: 1x NVIDIA GeForce GTX 690 4GB (Includes PhysX)
Office: Microsoft Office 2010 Home and Student (Full Retail Box Packaging)
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 2:16pm
The x79 plateform is more suited for people with quad sli setups or if they do heavy video rendering etc you can get a quality gaming machine for far under your budget
shot View Drop Down
  Quote shot Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 2:52pm
Hello Rick2197,
I personally would lower the memory speed to 1600MHz.  It will be more stable and you wont loose performance.  I also like the Corsair memory.  Nice choice.
DS will tell you that with the case you have chosen, and the one GTX690, you will not need the stage 4 cooling.  The 240MMRAD will work great and the airflow will be more than enough to keep the CPU comfortable.
It would not be my choice to overclock that video card since it is so great as is.  It is tops.
I'm not by any means a expert and you will get great advice to follow from others with more wisdom but that setup is very similar to mine and it KICKS ASS!.
Not one single issue and it runs cool as it can be.
Thanks,
Shot
Edited by shot - 30 Jul 2012 at 2:54pm
Intel i7 3820 3.8GHz
16GB 1600MHz Corsair Dominator
1200W Corsair Pro gold
180GB IntelSSD
1TB WD CB
1x GTX690
Auzen X-FI Forte 7.1
  Quote RICK2197 Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 3:31pm
thanks for the input.
Rick
  Quote RICK2197 Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 3:32pm
I will go back and rework my config.
Thanks,
Rick
  Quote tju76 Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 3:37pm
Yeah I would look at the z77 will sli 680s or 670s if your not going full liquid cooling I would not use the hailstorm, a beautiful case is the cosmos 2 look for it under spec ops section, that would be a sweet case with full watercooling or air cooling its a beauty
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 31 Jul 2012 at 6:38am
Hi RICK2197...    Here's my thoughts and a config to check out, kind of a combo of what was said and my spin.
Config  # 713948    Cost $ 3542
This gives you the same gaming performance for $1800 less.
The HafX case is tops for air cooled systems and doesn't need the noisy Zalman fan upgrade and has built in hot-swap bays.  Also doesn't need the noise suppression package.
The Z77 mobo is all gaming needs.  If you plan on going to a third graphics card, then the X79 would be needed, but that didn't seem to be an issue.
The 1050HX is great for sli.
For tops in dependability I put in the Noctua D14 cooler.  The stage 4 cooler you listed is also very good, just has more plumbing to worry about.
Just another way to go.  Good Luck.Big%20Smile
Edited by bprat22 - 31 Jul 2012 at 6:40am
  Quote RICK2197 Quote  Post ReplyReply bullet Posted: 31 Jul 2012 at 8:08am
Very interesting.
All the suggestions so far have been helpful and I appreciate them very much.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 31 Jul 2012 at 8:51am
Hi Rick,
That is a solid build from bprat22 with air cooling.
If you want to stick with the Hailstorm case here is a LC system using the Hailstorm. You also should consider increasing the warranty. The 3 year warranty only gives you 1 year of parts coverage.
Configuration: 713973 Cost: $4246
This page was generated in 0.1445313 seconds.
