Config help needed
Post Date: 2012-05-07
veggiepizza View Drop Down
  Quote veggiepizza Quote  Post ReplyReply bullet Topic: Config help needed
    Posted: 07 May 2012 at 4:34pm
Hi all, I'm in desperate need of a new comp.
Budget: Around $2000. Can go a little higher if need be to get something suitable for my needs.
Expectations: Run 2 monitors, main one a 22" 1680x1050 and  secondary 17" 1280x1024. I would like to replace the 17" monitor with a 24" or 27" sometime soon and make that the main one. I also might want to add a sound card later on and a 2nd hard drive.
Usage: play games, WoW, Diablo 3, Battlefield 3 etc on decent settings (as high as possible for my budget). I usually tend to multitask, so I have a game going on my larger screen with web browser and/or chat etc on my smaller screen. Would also like to watch blu-ray movies.
Special needs: Very important I like as quiet a comp as possible but I prefer to not go to any sort of liquid cooling. Also, a nice looking comp is a plus but not totally necessary.
Here is the build ive come up with so far, not sure if MB, memory or power supply are appropriate.
#685445
Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) (Does Not Support SLI or CrossFire)
System Memory: 8GB DDR3 2000MHz GTX-8 Digital Storm Certified Performance Series (Highly Recommended)
Video Card: 1x NVIDIA GeForce GTX 570 2.5GB (Includes PhysX) (EVGA 025-P3-1579-BR)
Asangard View Drop Down
  Quote Asangard Quote  Post ReplyReply bullet Posted: 07 May 2012 at 7:55pm
Hi veggiepiezza welcome to the forums.
For your budget I would look at the ODE v2 computers.  The ODE level 3 costs 1799 and comes with the GTX 580 graphics card.  The ODE level 4 costs 2049 and comes with AMD HD 7970 graphics card, a 120GB SSD and 1TB HDD.
Both the level 3 and level 4 have the 3770k CPU in them as well.
Check them out had see what you think
  Quote veggiepizza Quote  Post ReplyReply bullet Posted: 08 May 2012 at 9:51am
Thx Asangard. I did check out the ODE line of computers. But like I posted I dont want any sort of liquid cooling. Otherwise I probably would go for one of those.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 May 2012 at 10:16am
Hi veggiepizza.
How about this build.
Config # 685757    Cost $ 2110  EDIT  the second time I did it from scratch to check,  it came out to $2054 ?  The difference was the ram at 1600Mhz.  All you need and saves another $56.
For $16 more you get the gtx 680 for great gaming.  I dropped to the i5-3570k with no hyperthreading, but gaming doesn't need and dropped air cooler to the A50.  For stage 1 oc, the A 50 should be fine.
If you go to a 24" or 27" monitor then the gtx680 will really shine.
Just something to look at.Big%20Smile
Edited by bprat22 - 08 May 2012 at 10:37am
This page was generated in 4.101563E-02 seconds.
