Cleaning help!Post Date: 2013-11-12 |
Burr
Newbie Joined: 25 Feb 2013 Online Status: Offline Posts: 33 |
Topic: Cleaning help! Posted: 12 Nov 2013 at 9:12pm |
Hi,
I was curious as to whether or not there is a specific way, that's recommended, to clean the 120mm Liquid CPU Cooler on my ODE lvl 2? My CPU temps are great, but there is a constant clicking sound coming from one of the fans, and it tends to bother me, haha. I assume the clicking would be due to dust build up, as it never occurred when I first received my ODE lvl 2. Thanks. |
fstcvc
Quote Reply Posted: 12 Nov 2013 at 11:12pm |
If you haven't already done so, use compressed air to remove all dust from the fans and radiator. If the clicking sound continues, you might have a bad bearing on the fan and have to replace it. I believe you should be able to use any standard 120mm case fan as a replacement.
HailStorm II
