Check Hard Drive for errors
Post Date: 2010-09-22
!ender_ View Drop Down
  Quote !ender_ Quote  Post ReplyReply bullet Topic: Check Hard Drive for errors
    Posted: 22 Sep 2010 at 6:05pm
HD Tune is a handy free utility that comes with a tool to scan your hard drives for problems. Your hard drive will come pretty low on the list of suspects for the most part. But if you try most other things with no luck, it can not hurt to rule out a potential problem with your Hard Drive(s)
Download here:
Install and you will see:
First go to the error tab, seen in red. (no quick scanning) And hit start, if you get errors, post for help or contact Digital Storm directly here http://www.digitalstormonline.com/customerservice.asp including a link for a screenshot of your HDTune errors.
If you have more than one hard drive, the blue outline around the drop box will let you select which hard drive you want to test.
This page was generated in 8.398438E-02 seconds.
