CHASSISPost Date: 2014-08-19 |
Marah06
Newbie Joined: 03 Aug 2014 Online Status: Offline Posts: 50 |
Topic: CHASSIS Posted: 19 Aug 2014 at 4:54pm |
How do I open it on the vanquish ll level 2? I don't want to do anything wrong.
Quote Reply Posted: 19 Aug 2014 at 5:18pm |
Don't worry about doing anything wrong.
More Info is the only thing you can click on to open for added info. There is no Change option as in the custom builds. Good luck. |
Quote Reply Posted: 19 Aug 2014 at 11:55pm |
I'm not sure but I think the question was on how to take the case apart. If I'm wrong, ignore this post.
On the Vanquish case (Corsair 230T) there are two thumb screws in the back. Simply remove the screws and slide the panel toward the front of the computer. There is a picture of one of the thumbscrews in this thread...
The above thread will show you how to open the front fascia to clean the dust filters.
Quote Reply Posted: 20 Aug 2014 at 1:40am |
I think you're right, Snaike.
