CHASSIS
Post Date: 2014-08-19
Marah06 View Drop Down
  Quote Marah06 Quote  Post ReplyReply bullet Topic: CHASSIS
    Posted: Yesterday at 4:54pm
How do I open it on the vanquish ll level 2? I don't want to do anything wrong.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: Yesterday at 5:18pm
Don't worry about doing anything wrong.
More Info is the only thing you can click on to open for added info. There is no Change option as in the custom builds.
Good luck.
Snaike View Drop Down
  Quote Snaike Quote  Post ReplyReply bullet Posted: Yesterday at 11:55pm
I'm not sure but I think the question was on how to take the case apart.  If I'm wrong, ignore this post.
On the Vanquish case (Corsair 230T) there are two thumb screws in the back.  Simply remove the screws and slide the panel toward the front of the computer.  There is a picture of one of the thumbscrews in this thread...
The above thread will show you how to open the front fascia to clean the dust filters.
Big%20Smile
Vanquish II Ultimate
The Budget Beating Beast
  Quote bprat22 Quote  Post ReplyReply bullet Posted: Today at 1:40am
I think you're right, Snaike.
This page was generated in 6.640625E-02 seconds.
