Case Moding
Post Date: 2009-05-07
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Topic: Case Moding
    Posted: 07 May 2009 at 5:41pm
So I've started working on my first case mod... but was wondering, would the price/noise increase balance with the cooling capabilities with going with 6x 80mm fans compared to 2x 120mm fans?
justin.kerr View Drop Down
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 May 2009 at 6:26pm
Total air flow with matched dbs it will be pretty close. price wise it wil be cheaper to go with 2 x 120's, if you are comparing the same brand, model.
 It is not so much in the total air flow that counts. Air placement is crucial. Also it depends on the case. An open air case, you don't have to worry much about negative pressure occuring, but with a sealed up case, internal pressure becomes an issue.
 What brand of fans are you looking at? Are you going to power them directly off the PSU, or off the MB, or a fan controller?
I have set up a few cases with a lot of fans in the past.. My big case has had up to 28 120mm's running inside of it before, but its not a standard PC. lol
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 07 May 2009 at 9:33pm
It's on the front for intake.... yeah I know it's a little overkill, but 6 80mm look so freaking cool (Lol pun)... It has a lot of mesh, so exhaust isn't an issue...
And it really is a perfect fit for the 80s where I cut out... Idk lol.
Edit: Tbh, it's really about 'Wow' factor. Both will work perfectly fine.
Here is my model of my idea:
Edited by Zurginator - 07 May 2009 at 9:40pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 May 2009 at 9:49pm
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 07 May 2009 at 10:20pm
Those would defiantly be nice, but I have a deal for $2 a fan, with red LEDs. Great reviews on them too.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 May 2009 at 10:39pm
but what is the cfm and dba of those fans Zurginator?
Edited by DST4ME - 07 May 2009 at 10:39pm
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 07 May 2009 at 10:49pm
Clap Wow.... That's damn near 4 square feet of fan! Not actual fan blades area, but still, wow!
3.6 GHz E6850,       4 GB RAM, GTS 250,   TJ9, Win 7 64-bit
4.4 GHz i7 3930K, 16 GB RAM, GTX 670, 550D, Win 7 64-bit
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 08 May 2009 at 7:28am
Stats of the fans I'm looking at:
80mm:
-33.21 CFM
-22.41 dBA
-$2.49
120mm
-74.48 CFM
-29.28 dBA
$4.99
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 08 May 2009 at 1:44pm
well 6 of the smaller fans will generate just shy of 30 decibels... two of the 120s will generate almost 35 decibels
Your air flow will be significantly better with the smaller fans if there is not a back pressure problem.
If the CFM are accurate and you can make the mods your only loss point will be increased power consumption. You do not mention the power consumption but conservatively you can expect the six smaller fans to likely double your power needs for fans.
Not a huge deal unless you are already close on power.
Dave Ouch
Digital Storm 950Si - Q9450 Quad Core @ 3 Ghz
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
2 Western Digital 500 GB SATAII 7200 RPM HD
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 08 May 2009 at 1:51pm
One side note, fans at that cost are likely bargain bin, no name fans..
Might want to look at the fan type, single bearing fans tend to get noisy fast as they wear and have low MTBF... a decent fan is generally the same as a decent PSU 100,000 Hours.
They make multi-bearing, and fluid bearing fans that are generally quieter, spin faster and thus move more CFM for less dB...
Personally I like Scythe fans... like this one for $13, 120 MM and 60+ cfm for less dB than the 120s you posted.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185006
It is also a fluid bearing fan that will last practically forever.
Dave Ouch
Edited by Kliebor2 - 08 May 2009 at 1:52pm
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 08 May 2009 at 4:03pm
Well, these are actually Rosewill, and I've had some good stuff with them. Their tech support is amazing.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 May 2009 at 4:28pm
Scythe, delta, Sanyo Denki and Panaflo are the top of the line fans, rosewill shmorsewill
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 08 May 2009 at 4:41pm
Yeah, but Rosewill is starting, and think about it, Scythe, delta, Sanyo Denki and Panaflo were small unknown names at the beginning. Besides, they have stellar reviews and I've had good purchases with them.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 May 2009 at 4:49pm
personally I love delta and scythe, I wish they would make led fan also
This page was generated in 0.1367188 seconds.
