Case Differences
Post Date: 2007-08-30
jimbo View Drop Down
  Quote jimbo Quote  Post ReplyReply bullet Topic: Case Differences
    Posted: 30 Aug 2007 at 9:07pm
What are, if any, the differences between the Ultra and Extreme cases.
Its easy to see the shapes and paint job but are there others, examples, dirve holders, cooling flow number of drives.
The reason I'm asking is that there is almost a $300 dollar difference and if it's just a pretty face I'd rather spend in on upgrading the Extreme PSU, hard Drives and Liquid CPU cooling.
Life's too short
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 30 Aug 2007 at 9:10pm
its just paint. since theres a black extreme for same price as ultra.
  Quote jimbo Quote  Post ReplyReply bullet Posted: 30 Aug 2007 at 9:12pm
thought so, Thanks
Life's too short
Commast View Drop Down
Guest
Guest
  Quote Commast Quote  Post ReplyReply bullet Posted: 30 Aug 2007 at 11:16pm
They're not the same !!! The Ultra case is a CM Stacker 380 case, i believe and the Extreme is the Siverstone TJ-09 case.
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Posted: 30 Aug 2007 at 11:26pm
He's right...
The Ultra is a black or silver CM Stacker 830 and the Extreme is the Silverstone TJ-09
Kenny View Drop Down
Digital Storm Engineering
  Quote Kenny Quote  Post ReplyReply bullet Posted: 30 Aug 2007 at 11:32pm
The Ultra Case is a Cooler Master 830 or 832 Case
We're here with you !    &(*_~)&
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 1:14am
Check out this review of the TJ09.... Impressive. I liked the line about the box it comes in is tougher than a lot of other cases.
http://www.barrys-rigs-n-reviews.com/reviews/2007/hardware/tj09/tj09_1.htm
Edited by Bill the Cat - 31 Aug 2007 at 1:15am
commast View Drop Down
Guest
Guest
  Quote commast Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 1:48am
I agree Big%20smile The TJ-09 is one cool looking case. DS really know their stuffs and they must subscribe to MaximumPC too Wink. If i remember correctly, I think they send 2 pcs to MaximumPC for reviews in the past.
  Quote Kenny Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 4:01am
Yes, you right, we have been send 2 pcs to MaximumPC for reviews in the past. Also, we will have the new Super Extreme case that is Silverstone TJ-10, coming soon.
Larry View Drop Down
  Quote Larry Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 12:00pm
If you like just a plain case that looks good and does the job for less, go with the PRO.  It is really a nice case and it is not flashy.  I am an old timer when it comes to cases.
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 12:15pm
I originally ordered a PRO case, but apparently the PRO can't handle 8800 GTS/GTX cards without "hacking" up the case; moving drive bays that are in the way, or something like that. So I switched to the TJ09. It's a substantial cost increase, but I like cases that are big enough so that each of the components inside feels lonely.
UPDATE:
"Hacking up" may have some unintended negative connotations. Please substitute "skillfully modifying".
Edited by Bill the Cat - 31 Aug 2007 at 8:08pm
  Quote jimbo Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 1:27pm
The info and link are a great help
This realy helps in making my choice. Now I can do a 'real' compare to determine which is best for me.
Life's too short
  Quote Larry Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 3:09pm
I have the 8800 GTX in my PRO case.  They did not hack it as far as I can tell.  I wonder if they had to move bays?  Any help on this DS?
Guest
Guest
  Quote commast Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 7:56pm
The Pro case DS using right now is the Silverstone TJ-04, i think, and the specs are : W=8.5 in, D= 18.5 in and H= 17.6 in. It might be a little tight to fit the Nvidia 8800GTX but i don't know. Originally when i order my pc a few days ago, i choose the Pro case with the Nvidia 8800GTS and Alex never said it wouldn't fit, but i decided to go to the bigger case since i am planning to add more HDDs later on.
