bulldozer
Post Date: 2010-07-15
kainhall View Drop Down
  Quote kainhall Quote  Post ReplyReply bullet Topic: bulldozer
    Posted: 15 Jul 2010 at 3:27am
well, i got tired of saying amds dozer would be boss, and having no links etc. well heres a link.
now theres a mistake in there. if you read the first responce you will get it.
this means, that the intel chips, and the amd modules (mods for short?) will be almost the same. execpt it uses mods and not chips. i really dont know what this means. but from what i understand, its basicly 2 cores, but they share the recources and are very "close" with one another. sounds like intels cores are not like amds cores!!!
and rember back in teh athlon 64 days. when amd did a new achulctulre. well this is teh same thing, its totaly new, so it should be the same as the athlon, on top for a shile, then most likly slowly getting worse and worse. but if amd learned there lesson, they should be able to do the more cores, higher clocks, more L3 game right allong with intel.
either teh dozer fails and we continue on, it it atleast matches intels offerings, and we have a price war, or a clock speed war. i would love to see cpus at 4.5 ghz stock. that would be sweet!
thanks for your time
Edited by kainhall - 15 Jul 2010 at 3:30am
steam friends is kainhall
This page was generated in 2.539063E-02 seconds.
