Build Info needed
Post Date: 2012-08-20
lennyx View Drop Down
  Quote lennyx Quote  Post ReplyReply bullet Topic: Build Info needed
    Posted: 20 Aug 2012 at 5:47pm
Budget: 1500
General/Gaming
Firewire Port for Audio Interface
Time is getting close to pulling a trigger on something- I been checking out builds, I initially had a budget 2K but would like some info 1st on whats possible.
If i was to game on 1- 1080p monitor, how much difference will I seen between the 660ti, 670, 680.          Is 680 even a smart buy for a monitor in that rez? or is it overkill.
If possible I would like the system with a 670,   3750 OC'd in a mid size case.
Honestly I can pull a trigger on any of the ODE but would like to know what system will cater to what use, Thanks
SpicierMire View Drop Down
  Quote SpicierMire Quote  Post ReplyReply bullet Posted: 20 Aug 2012 at 7:31pm
Hi lennyx
It mostly depends on the antialiasing settings and/or GPGPU functionality (e.g PhysX) rather than resolution today. Sure, the 660ti will max out most everything on 1080p, but will it be able to handle high quality AA (i.e. > 4x MSAA) or turn up PhysX settings to 'High' on Batman: Arkham City for that matter? Even the 680 will struggle in some scenarios!
To answer your question in a precise manner, the difference will not be a whole lot, but the extra GPU horsepower on the 680 will go a long way if you're planning on playing, say, Crysis 2 w/ Hi-res textures on DX11. If you're talking 3d Vision, though, that's a whole 'nother story  Smile
(I'm not quite sure btw if you can run a 680 without hitting bottlenecks on other components on a $1500 budget, so 'a smart buy' would have you going for the 660ti)
  Quote lennyx Quote  Post ReplyReply bullet Posted: 20 Aug 2012 at 8:20pm
what may be a bottleneck ?
Asangard View Drop Down
Digital Storm Live Chat Rep.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 20 Aug 2012 at 9:01pm
Hi lennyx,
Here is a link where you can compare just about any 2 graphics cards.  It covers many different games and resolutions.  I have it set to compare the 660ti to the 670 but you can change it to any 2 cards.
It doesn't cover the 1920 x 1080 resolution so the closest would be the 1920 x 1200.
Here is a custom build that is under 1500 and the case has a front Firewire connector.  Other comments after build.
Ticket #720352  Cost $1494
Chassis Model: Special Deal Hot Seller - Corsair Carbide 500R (Black Finish)
Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) (Does Not Support SLI)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (16MB Cache)
Extreme Cooling: AIR: Stage 1: Cooler Master Hyper 212 EVO (High Performance Cooler)
I used the 500R case. It is a mid tower case with good air flow and is available in black or white and has a front Firewire connector as you requested.
I used the GTX 670 graphics card as it is still within your 1500 budget.
For stage 1 OC the Cooler Master Hyper 212 EVO CPU cooler will do just fine.
I hope this helps and let us know what you think.
