Build advicePost Date: 2012-02-25 |
xii
Topic: Build advice Posted: 25 Feb 2012 at 9:42am |
I had a great super detailed post for this gaming rig - but it didn't post and now I need to start over.
Ok so here is the build. 659477I was wondering a few things - like should I go with 3x SLI or quad? Is the difference that big? How many monitors would I be able to use at 3x SLI? Quad? Anyone have a monitor recommendation? I'm worried about liquid cooling, I know next to nothing about it. What if it leaks? How often do I fill it? Do I fill it? For the hard drives - should I keep the SS (Solid State) main drive and get a 7200 drive like shown? Or 2 SS's in raid? Thoughts? Is having the CPU and graphics cards overclocked a good idea? Is it safe? Do you think that touch-screen-thing is even applicable to the system as is? Anyway - thanks for your inputs - the original post was much cleaner. |
