Budget Civ 5 buildPost Date: 2010-08-27 |
Raxmus
Newbie Joined: 26 Aug 2010 Online Status: Offline Posts: 2 |
Topic: Budget Civ 5 build Posted: 27 Aug 2010 at 1:11am |
Anyone care to comment on my build? Other than web-surfing and watching video, my primary use will be playing Civilization 5 for hundreds of hours. I'm also planning on playing Fallout New Vegas and the next Elder Scrolls game when they come out. I plan to use this machine for 3-4 years, and might upgrade the video card if necessary in the future. I'm going to use this machine with a 1920 X 1080 monitor. I have a budget of $1300 so I'm trying to maximize my bang for the
buck as much as possible. Is there anything I could do to tweak my build to get an even better bang for the buck ratio?
Ticket Number: 436097 Total Price with Instant Savings: $1,270.00 Direct Load URL: http://www.digitalstormonline. Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master CM 690 II Advanced Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 760 2.8GHz (Quad Core) Motherboard: EVGA P55M SLI (Intel P55 Chipset) System Memory: 4GB DDR3 1333MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Digital Storm Certified (Dual SLI Compatible) (Silent Edition Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (320GB Western Digital (16MB Cache) (7200 RPM) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 460 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: High Performance Cooler (Compatible With ONLY i5/AMD Processors) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) |
!ender_
DS Veteran Joined: 24 Oct 2007 Online Status: Offline Posts: 4219 |
Quote Reply Posted: 27 Aug 2010 at 1:21am |
looks really good!
if your main use is gaming id suggest springing for the 470, its $80 more, well worth it imo.
if not, at least spend the extra $9 and get a 500gb HDD, its pretty much detrimental go to under 500gb; you'd be paying $1 per 20gb haha
