Blue Screen, then RebootPost Date: 2012-10-12 |
Scrumdown
Newbie Joined: 12 Oct 2012 Online Status: Offline Posts: 1 |
Topic: Blue Screen, then Reboot Posted: 12 Oct 2012 at 4:26pm |
My DS seems to constantly be crashing to a blue screen, with a bunch of code on it, for less than a second, so I cannot read anything. Then, the computer automatically reboots, gets to the screen that say soemthing like windows did not shut down properly, and ask if I want to start windows normally or in safe mode. This crashing occurs at various tasks; playing games, surfing the internet, etc.
Can someone please also tell me how to post my system specs, without having to type all of them in, please?
I check the DS forums and went through the laborious process of 'reseating' all my components within the case. That did not work.
I am not sure if my CPU or GPU are overclocked, am very new to this tpe of machine.
I then ran Prime95 for about four hours, and ended up with various errors which will be posted at the end of this message. Can someone please help? This constant rebooting is driving me nuts, and I would hope I would not have to go through this for what I spent on this beast!
Worker #2 [Oct 12 16:21] Worker starting [Oct 12 16:21] Setting affinity to run worker on logical CPU #1 [Oct 12 16:21] Beginning a continuous self-test to check your computer. [Oct 12 16:21] Please read stress.txt. Choose Test/Stop to end this test. [Oct 12 16:21] Test 1, 4000 Lucas-Lehmer iterations of M19922945 using FFT length 1024K. [Oct 12 16:22] Test 2, 4000 Lucas-Lehmer iterations of M19922943 using FFT length 1024K. [Oct 12 16:24] Test 3, 4000 Lucas-Lehmer iterations of M19374367 using FFT length 1024K. [Oct 12 16:25] Test 4, 4000 Lucas-Lehmer iterations of M19174369 using FFT length 1024K. [Oct 12 16:27] Test 5, 4000 Lucas-Lehmer iterations of M18874369 using FFT length 1024K. [Oct 12 16:29] Test 6, 4000 Lucas-Lehmer iterations of M18874367 using FFT length 1024K. [Oct 12 16:30] Test 7, 4000 Lucas-Lehmer iterations of M18474367 using FFT length 1024K. [Oct 12 16:32] Test 8, 4000 Lucas-Lehmer iterations of M18274367 using FFT length 1024K. [Oct 12 16:33] Test 9, 4000 Lucas-Lehmer iterations of M18274369 using FFT length 1024K. [Oct 12 16:35] Test 10, 4000 Lucas-Lehmer iterations of M18074369 using FFT length 1024K. [Oct 12 16:36] Self-test 1024K passed! [Oct 12 16:36] Test 1, 800000 Lucas-Lehmer iterations of M172031 using FFT length 8K. [Oct 12 16:38] Test 2, 800000 Lucas-Lehmer iterations of M163839 using FFT length 8K. [Oct 12 16:39] Test 3, 800000 Lucas-Lehmer iterations of M159745 using FFT length 8K. [Oct 12 16:41] Test 4, 800000 Lucas-Lehmer iterations of M157695 using FFT length 8K. [Oct 12 16:42] Test 5, 800000 Lucas-Lehmer iterations of M155649 using FFT length 8K. [Oct 12 16:44] Test 6, 800000 Lucas-Lehmer iterations of M153599 using FFT length 8K. [Oct 12 16:45] Test 7, 800000 Lucas-Lehmer iterations of M147455 using FFT length 8K. [Oct 12 16:47] Test 8, 800000 Lucas-Lehmer iterations of M143361 using FFT length 8K. [Oct 12 16:49] Test 9, 800000 Lucas-Lehmer iterations of M141311 using FFT length 8K. [Oct 12 16:51] Test 10, 800000 Lucas-Lehmer iterations of M135169 using FFT length 8K. [Oct 12 16:52] Self-test 8K passed! [Oct 12 16:52] Test 1, 560000 Lucas-Lehmer iterations of M212991 using FFT length 10K. [Oct 12 16:54] Test 2, 560000 Lucas-Lehmer iterations of M210415 using FFT length 10K. [Oct 12 16:55] Test 3, 560000 Lucas-Lehmer iterations of M208897 using FFT length 10K. [Oct 12 16:57] Test 4, 560000 Lucas-Lehmer iterations of M204799 using FFT length 10K. [Oct 12 16:58] Test 5, 560000 Lucas-Lehmer iterations of M200705 using FFT length 10K. [Oct 12 17:00] Test 6, 560000 Lucas-Lehmer iterations of M196607 using FFT length 10K. [Oct 12 17:01] Test 7, 560000 Lucas-Lehmer iterations of M194561 using FFT length 10K. [Oct 12 17:03] Test 8, 560000 Lucas-Lehmer iterations of M188415 using FFT length 10K. [Oct 12 17:04] Test 9, 560000 Lucas-Lehmer iterations of M186369 using FFT length 10K. [Oct 12 17:06] Test 10, 560000 Lucas-Lehmer iterations of M184319 using FFT length 10K. [Oct 12 17:07] Self-test 10K passed! [Oct 12 17:07] Test 1, 4500 Lucas-Lehmer iterations of M17432577 using FFT length 896K. [Oct 12 17:09] Test 2, 4500 Lucas-Lehmer iterations of M17432575 using FFT length 896K. [Oct 12 17:10] Test 3, 4500 Lucas-Lehmer iterations of M17115073 using FFT length 896K. [Oct 12 17:12] Test 4, 4500 Lucas-Lehmer iterations of M16815071 using FFT length 896K. [Oct 12 17:13] Test 5, 4500 Lucas-Lehmer iterations of M16515073 using FFT length 896K. [Oct 12 17:15] Test 6, 4500 Lucas-Lehmer iterations of M16515071 using FFT length 896K. [Oct 12 17:17] Test 7, 4500 Lucas-Lehmer iterations of M16297569 using FFT length 896K. [Oct 12 17:18] Test 8, 4500 Lucas-Lehmer iterations of M15997567 using FFT length 896K. [Oct 12 17:20] Test 9, 4500 Lucas-Lehmer iterations of M15597569 using FFT length 896K. [Oct 12 17:21] Test 10, 4500 Lucas-Lehmer iterations of M15597567 using FFT length 896K. [Oct 12 17:23] Self-test 896K passed! [Oct 12 17:23] Test 1, 5300 Lucas-Lehmer iterations of M14942209 using FFT length 768K. [Oct 12 17:23] FATAL ERROR: Rounding was 0.5, expected less than 0.4 [Oct 12 17:23] Hardware failure detected, consult stress.txt file. [Oct 12 17:23] Torture Test completed 40 tests in 1 hours, 1 minutes - 1 errors, 0 warnings. [Oct 12 17:23] Worker stopped. Worker #3 [Oct 12 16:21] Worker starting [Oct 12 16:21] Setting affinity to run worker on logical CPU #2 [Oct 12 16:21] Beginning a continuous self-test to check your computer. [Oct 12 16:21] Please read stress.txt. Choose Test/Stop to end this test. [Oct 12 16:21] Test 1, 4000 Lucas-Lehmer iterations of M19922945 using FFT length 1024K. [Oct 12 16:22] Test 2, 4000 Lucas-Lehmer iterations of M19922943 using FFT length 1024K. [Oct 12 16:24] Test 3, 4000 Lucas-Lehmer iterations of M19374367 using FFT length 1024K. [Oct 12 16:26] Test 4, 4000 Lucas-Lehmer iterations of M19174369 using FFT length 1024K. [Oct 12 16:27] Test 5, 4000 Lucas-Lehmer iterations of M18874369 using FFT length 1024K. [Oct 12 16:29] Test 6, 4000 Lucas-Lehmer iterations of M18874367 using FFT length 1024K. [Oct 12 16:30] Test 7, 4000 Lucas-Lehmer iterations of M18474367 using FFT length 1024K. [Oct 12 16:32] Test 8, 4000 Lucas-Lehmer iterations of M18274367 using FFT length 1024K. [Oct 12 16:33] Test 9, 4000 Lucas-Lehmer iterations of M18274369 using FFT length 1024K. [Oct 12 16:35] Test 10, 4000 Lucas-Lehmer iterations of M18074369 using FFT length 1024K. [Oct 12 16:36] Self-test 1024K passed! [Oct 12 16:36] Test 1, 800000 Lucas-Lehmer iterations of M172031 using FFT length 8K. [Oct 12 16:38] Test 2, 800000 Lucas-Lehmer iterations of M163839 using FFT length 8K. [Oct 12 16:39] Test 3, 800000 Lucas-Lehmer iterations of M159745 using FFT length 8K. [Oct 12 16:41] Test 4, 800000 Lucas-Lehmer iterations of M157695 using FFT length 8K. [Oct 12 16:42] Test 5, 800000 Lucas-Lehmer iterations of M155649 using FFT length 8K. [Oct 12 16:44] Test 6, 800000 Lucas-Lehmer iterations of M153599 using FFT length 8K. [Oct 12 16:45] Test 7, 800000 Lucas-Lehmer iterations of M147455 using FFT length 8K. [Oct 12 16:47] Test 8, 800000 Lucas-Lehmer iterations of M143361 using FFT length 8K. [Oct 12 16:48] Test 9, 800000 Lucas-Lehmer iterations of M141311 using FFT length 8K. [Oct 12 16:50] Test 10, 800000 Lucas-Lehmer iterations of M135169 using FFT length 8K. [Oct 12 16:51] Self-test 8K passed! [Oct 12 16:51] Test 1, 560000 Lucas-Lehmer iterations of M212991 using FFT length 10K. [Oct 12 16:53] Test 2, 560000 Lucas-Lehmer iterations of M210415 using FFT length 10K. [Oct 12 16:54] Test 3, 560000 Lucas-Lehmer iterations of M208897 using FFT length 10K. [Oct 12 16:56] Test 4, 560000 Lucas-Lehmer iterations of M204799 using FFT length 10K. [Oct 12 16:57] Test 5, 560000 Lucas-Lehmer iterations of M200705 using FFT length 10K. [Oct 12 16:59] Test 6, 560000 Lucas-Lehmer iterations of M196607 using FFT length 10K. [Oct 12 17:00] Test 7, 560000 Lucas-Lehmer iterations of M194561 using FFT length 10K. [Oct 12 17:02] Test 8, 560000 Lucas-Lehmer iterations of M188415 using FFT length 10K. [Oct 12 17:03] Test 9, 560000 Lucas-Lehmer iterations of M186369 using FFT length 10K. [Oct 12 17:05] Test 10, 560000 Lucas-Lehmer iterations of M184319 using FFT length 10K. [Oct 12 17:06] Test 11, 800000 Lucas-Lehmer iterations of M172031 using FFT length 10K. [Oct 12 17:09] Self-test 10K passed! [Oct 12 17:09] Test 1, 4500 Lucas-Lehmer iterations of M17432577 using FFT length 896K. [Oct 12 17:10] Test 2, 4500 Lucas-Lehmer iterations of M17432575 using FFT length 896K. [Oct 12 17:12] Test 3, 4500 Lucas-Lehmer iterations of M17115073 using FFT length 896K. [Oct 12 17:13] Test 4, 4500 Lucas-Lehmer iterations of M16815071 using FFT length 896K. [Oct 12 17:15] Test 5, 4500 Lucas-Lehmer iterations of M16515073 using FFT length 896K. [Oct 12 17:16] Test 6, 4500 Lucas-Lehmer iterations of M16515071 using FFT length 896K. [Oct 12 17:18] Test 7, 4500 Lucas-Lehmer iterations of M16297569 using FFT length 896K. [Oct 12 17:20] Test 8, 4500 Lucas-Lehmer iterations of M15997567 using FFT length 896K. [Oct 12 17:21] Test 9, 4500 Lucas-Lehmer iterations of M15597569 using FFT length 896K. [Oct 12 17:23] Test 10, 4500 Lucas-Lehmer iterations of M15597567 using FFT length 896K. [Oct 12 17:24] Self-test 896K passed! [Oct 12 17:24] Test 1, 5300 Lucas-Lehmer iterations of M14942209 using FFT length 768K. [Oct 12 17:24] FATAL ERROR: Rounding was 0.5, expected less than 0.4 [Oct 12 17:24] Hardware failure detected, consult stress.txt file. [Oct 12 17:24] Torture Test completed 41 tests in 1 hours, 3 minutes - 1 errors, 0 warnings. [Oct 12 17:24] Worker stopped. Worker #5 [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Possible hardware failure, consult readme.txt file, restarting test. [Oct 12 17:27] ERROR: ILLEGAL SUMOUT [Oct 12 17:27] Maximum number of warnings exceeded. [Oct 12 17:27] Torture Test completed 43 tests in 1 hours, 6 minutes - 0 errors, 100 warnings. [Oct 12 17:27] Worker stopped. |
Quote Reply Posted: 12 Oct 2012 at 5:08pm |
Hi Scrumdown. So many things it could be.
Download and run BlueScreenView and WhoCrashed to see crash file. Google the fault it mentions in first few lines to get an idea of cause. Do a System Restore in case something recently installed is messing with the system. Go into Bios, usually Del key on boot and load defaults, F5, and save/exit F10 to remove overclocks. Check your motherboard manual for proper procedure since every mobo is different. Remove all ram sticks and seat one at a time in slot one., usually right most slot, and run to see if problem changes. Unplug all externals except keyboard/mouse and monitor and run to see. If you have a programmable mouse/keyboard then try an older basic one. Download and run Malwarebytes to see if it detects a worm., virus etc. If none of this helps tonight then call DS in the morning. Good luck. |
Quote Reply Posted: 13 Oct 2012 at 11:31am |
That's some great advice. I would also suggest to see if the system runs good after BIOS defaults which will remove any overclocking.
