ablahblah
Topic: blah's Post-RMA DS Review! Posted: 03 Jan 2011 at 1:45pm |
Finally!! It's been a year since I got this rig, and after being stuck with a handful of hardware issues it's awesome to have it going at 100% again! System Specs as of now: Chassis - Silverstone Raven RV01 Processor - Intel Core i7 920 Motherboard - Asus Sabertooth X58 System Memory - 6GB 1333Mhz Mushkin DDR3 (3x2GB Tri-Channel set) Power Supply - TechNPS 750w Modular PSU Hard Drive(s) - WD Velociraptor 150GB Internet Access - Integrated motherboard LAN Video Card(s) - 1x EVGA GTX 570 with Hi-Flow Bracket Audio - Integrated Motherboard Audio Cooling - Thermalright Venomous X (Dual Fan - Silverstone AP121 + Aerocool Shark) Internal Lighting - Dual 12" Blue CCFL bars CPU Overclocking - 3.902Mhz (BCLK 186, Vcore 1.2) (4.1Ghz or so with Turbo enabled) Memory Overclocking - 1419Mhz Video Overclocking - GTX 570 set to EVGA SuperClocked speeds - Original Review Post http://digitalstormonline.com/forums/forum_posts.asp?TID=10106- Feedback about DS's service Well, my rig has changed a bit ever since the original build back in june almost two years ago. The original build itself was rock solid, save for a lockup glitch that happened for a little while with SLI'd 9600 GTs that I can't blame DS at all for. Just a random mishap that I'll say was just associated with Windows XP I guess. A little over a year later, and I decided to get the motherboard swapped. Errgh, really I needed the motherboard swapped; I wasn't aware of how fragile the 1366 socket was and bent a pin by accident. It was a little bit of a bumpy ride from there, had some hardware mysteries and failures pop up, but the warranty DS offers came through in this time. In total, I went through a second motherboard swap because the EVGA board I switched to had a defective mem slot (possibly from shipping I'm guessing, still a mystery), as well as a PSU RMA (dunno...freak failure is the best I can explain it. Simply, in november, the PSU clicked and wouldnt start again). The RMA process was simple, fluid, and straightforward, and after two years, I really have no complaints/concerns with DS's service and dedication to their customers. As for performance, well, I've never been happier with a computing system before. I can get to the login screen within 23 seconds usually, which is pretty darn fast for me. In games, it performs well; even in Black Ops it's luckily one of the systems that can run it with barely any issues. I also use it for some video rendering, which is does great at too. The single, single thing about it that nags me sometimes is the fact that the PSU power cord is a bit jiggly. I'll yank it out by accident once in while when I occasionally need to move the case around. It's one kickass rig, and I thank all of DS for their outstanding commitment to their customers. Well....wall of text is out of the way. Picture time! Desk  Side  Front  Side again  GTX 570 with Hi-Flow Bracket if anyone wants to see what it is  Cover opened  Internals (Yes, Ven X is offset for a reason. Main exhaust fan on the Raven chassis is offset by standard somehow)  Side panel shot  Digital Storm Logo (oh, and notice I have my G700 receiver stuck up at the top of the "Stealth" i/o cover... I think it's a cool touch with the RV01 being inspired by the F117 Nighthawk and all, wireless signal getting covertly received from there hehe.
Edited by ablahblah - 05 Mar 2011 at 2:07am
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
DST4ME
Posted: 03 Jan 2011 at 1:49pm |
Glad you got yours back running again at 100%
Posted: 05 Jan 2011 at 1:33am |
I'm glad to see you back up and running as well. Thanks for the updated review and pictures!
Posted: 05 Jan 2011 at 8:01pm |
Nice to see things back in top-shape! I had been following your issues for awhile, glad to see it worked out.  I was looking at your desk layout, how do you work with the limited space for your mouse, high dpi settings?
ablahblah
Posted: 05 Jan 2011 at 9:18pm |
I've adapted to the tiny space and I can really get some precise movements in by using high DPI settings but low in-game sensitivity (In black ops, I think my sensitivity is around 1 and a half blocks in view settings). 3700dpi is the sweet spot for me. Really, the way I use my mouse the hilariously small space I'd say is comparable to using a high precision knife or scalpel of some sort lol; my pinky and index finger are pretty much fighting with each other all the time that allows really minute movements.
Oh, and the SteelSeries QcK mousepad I have under there helps too (actually, not sure whether it's easy to notice in that shot, but it's sitting under there alright. Majority [over 50% of it] is squashed under my keyboard though)
Edited by ablahblah - 05 Jan 2011 at 9:22pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Posted: 05 Jan 2011 at 9:29pm |
I was just wondering, as I have a very similar setup to that. Except yours looks much more nice than mine, I have a 10 year old Belkin mousepad that halfway hangs over the side and is torn on the edges.  I'm right around 3200dpi, I'll have to give 3700 a shot to see how that works out.
justin.kerr
Posted: 05 Jan 2011 at 9:32pm |
maxyme
Posted: 05 Jan 2011 at 11:46pm |
i wish i could use 3700dpi my non ds computer is so crappy the mouse lags half the time so its impossible to use anything over 1800 for me.
Steam:pcmaster160
ablahblah
Posted: 06 Jan 2011 at 12:02am |
glass mouse pad? are those really any good? and i'm assuming you mean the steel series i series, amirite :D
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
justin.kerr
Posted: 06 Jan 2011 at 12:07am |
I like them, I usually run the same mouse, mouse pad, keyboard on my regular rigs, so I don't have to adjust all the time, but the Drunken Monkey likes mechanical keyboards so there is a steady fight.... like Bender, and DST
damnit it says glass
Edited by justin.kerr - 06 Jan 2011 at 12:12am
ablahblah
Posted: 06 Jan 2011 at 5:50pm |
out of curiosity, what mouse grip do you guys use on your mice? oddly enough I can use a palm grip pretty well *on my Logitech G700* even in the tiny *mousing* space I have lol.
Edited by ablahblah - 06 Jan 2011 at 7:06pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
DST4ME
Posted: 06 Jan 2011 at 6:10pm |
lol for one pc I just use my glass table that the mouse and keyboard are already on
ablahblah
Posted: 06 Jan 2011 at 6:12pm |
DST...what sensor is that mouse...lol? my G700 absolutely hates my glass table.
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
justin.kerr
Posted: 06 Jan 2011 at 6:18pm |
Originally posted by ablahblah
out of curiosity, what grip do you guys use? oddly enough I can use a palm grip pretty well even in the tiny space I have lol.
we still talking about mice here????
DST4ME
Posted: 06 Jan 2011 at 6:26pm |
lol I don't even know, its an oldarse mx700 that is the one used on glass, the one I'm using with the DST is the desktop wave pro with 1600 dpi, this one does not like glass
Edited by DST4ME - 06 Jan 2011 at 6:32pm
DST4ME
Posted: 06 Jan 2011 at 6:30pm |
justin.kerr
Posted: 06 Jan 2011 at 6:37pm |
I think that may be my new sig..
ablahblah
Posted: 06 Jan 2011 at 6:45pm |
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
DST4ME
Posted: 06 Jan 2011 at 7:02pm |
Oni-Tenshi
Posted: 06 Jan 2011 at 7:03pm |
Sig'd
ablahblah:
justin.kerr:
ablahblah
Posted: 06 Jan 2011 at 7:04pm |
IIII amm going to keeeeel youuuuu
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
justin.kerr
Posted: 06 Jan 2011 at 7:05pm |
DST4ME
Posted: 06 Jan 2011 at 7:09pm |
ablahblah
 aaaahhhhhh the internet is a horrible, embarassing place sometimes
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
DST4ME
Posted: 06 Jan 2011 at 7:10pm |
ablahblah
Posted: 06 Jan 2011 at 7:19pm |
I'm 15 dangit, this is one of the reasons why I avoided Facebook originally  me and my big mouth, blurbs out stuff without thinking at times
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Oni-Tenshi
Posted: 06 Jan 2011 at 7:23pm |
Apparently you like to use your fingers without thinking as well.
ablahblah:
justin.kerr:
ablahblah
Posted: 06 Jan 2011 at 7:24pm |
on a mouse and in CoD, sure, whatever.
Edited by ablahblah - 06 Jan 2011 at 7:24pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
justin.kerr
At 15, I understand, it takes a while for a guy to find his preferred grip.
ablahblah
Posted: 06 Jan 2011 at 7:25pm |
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Oni-Tenshi
Posted: 06 Jan 2011 at 7:28pm |
Originally posted by justin.kerr
At 15, I understand, it takes a while for a guy to find his preferred grip. |
I still haven't found a good grip. If I go on for too long, my hand starts to fall asleep.
<FONT style=": #000000"> Where the heck did this come from????
Edited by Oni-Tenshi - 06 Jan 2011 at 7:31pm
ablahblah:
justin.kerr:
ablahblah
Posted: 06 Jan 2011 at 7:30pm |
 *no comment.
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
DST4ME
Posted: 06 Jan 2011 at 10:17pm |
LOL keep practicing, you'll find your grip
rholyrag
Posted: 07 Jan 2011 at 2:59am |
Cretae
Posted: 11 Jan 2011 at 11:39pm |
Ablah, don't pay any attention to those old guys, they're just jealous!
I've been MIA for a bit, but I'm delighted to drop back in and find your tribulations have been resolved, and you are happy with your new config! It's really lookin' good. Happy new year!
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
I can make my mind think... anything....
