BisonCap AVI Playback issuePost Date: 2013-08-20 |
riesnich
Newbie Joined: 08 Oct 2012 Online Status: Offline Posts: 5 |
Topic: BisonCap AVI Playback issue Posted: 20 Aug 2013 at 2:00pm |
Hi all,
I recently recorded a video using the Webcam Installer 4.04 that came with my laptop using the BisonCap camera to create an AVI file as usual. Other videos I have made work no problem however this file will not play in any program (including VLC). I have tried various avi repair programs without success, even AVI preview won't play it. If I try to convert it to a different format with Any Video converter it states the video has zero frames. Is there any way I can fix this? The size of the video is 3.76GB so theory says the frames exist somewhere in it. Thanks in advance! |
outofline
Newbie Joined: 26 Aug 2013 Online Status: Offline Posts: 1 |
Quote Reply Posted: 26 Aug 2013 at 8:12pm |
Have you tried AppGeeker, converts anything.
Nothing special but works, worth giving a try. |
Quote Reply Posted: 26 Aug 2013 at 9:15pm |
Try to save in a different format than AVI? If the software does not have the option, try a different program as well.
This might help: http://www.wikihow.com/Record-from-a-Webcam |
Martin Jacob
Newbie Joined: 04 Sep 2013 Online Status: Offline Posts: 1 |
Quote Reply Posted: 04 Sep 2013 at 4:16pm |
As Alex suggested, just try to convert it in different format. After that also you are not able to play it then I think your video gets corrupted. Give a try to demo version of “remo repair avi” to check its performance.
