Posted: 04 Oct 2011 at 11:57am |
 Thanks, I'll try it out later today.
RiceEatin2000GT
Posted: 04 Oct 2011 at 12:48pm |
Originally posted by bprat22
 Thanks, I'll try it out later today. |
no prob, its wierd because your not able to acess the options menu where u change video settings when ur not spawned.
Posted: 04 Oct 2011 at 1:39pm |
Ya, that's what stumped me. Damn Betas.  Thanks to you, Rice, I just tried BF3 again, this time messing with the graphics and here it is; All on High, af x16, aa x4, motion blur?? On, AAPost??? Medium, whatever the last two are Outside the frames were 32-38 sometimes 50s when action slowed Inside Metro frames were 36-45, again 50s when less explosions, etc Changing aa and af didn't seem to do much. Didn't even try Ultra, but i will later. Even the mid 30s played pretty smooth, no problem locking on, only stuttered a little when panning fast. Definitely no slide-show problem. It did slow a little after a while, which I believe is a driver problem, still using 275.33. My beast of a rig ODE 0  plays to my satisfaction.  You guys with sli570, 580 etc are gonna love this.
Doc
Posted: 04 Oct 2011 at 3:52pm |
You guys are making me a bit nervous with my gtx560.
Hopefully the retail will be alot better optimized than the beta. If not, than a little more tweaking is in order. |
My trusty GTX275 is running the beta at 35-40 fps on medium settings. Ultra gets me 23-27fps. But it runs and looks great on medium. Can't believe you won't be able to run high settings with good framerates, probably even ultra.
Having said that my 570 is on the UPS truck as I type.
Anyone know how to change a video card without breaking stuff?
Posted: 04 Oct 2011 at 5:05pm |
Those frames posted were on high. 35-45 on high and on medium they stay in the 50s mostly. Even at 35-45 with high settings, like you observed, the game runs and looks good. On medium it's even better, but not what a 580 or sli 570 will do. It's pretty much what I expected. Tweeking aa and af didn't do much to help or hurt the fps unlike other games I have, which seemed a little strange. The newest drivers supposedly increase fps up to 38%, if that's believable and on 2510 res. I'll see what the new driver does on 1920 res. Doc, I think your 570, if single, will probably add 20% to what I have.
Muggz
Posted: 04 Oct 2011 at 9:14pm |
How do you think SLI 480s will manage?
maxyme
Posted: 04 Oct 2011 at 9:19pm |
a 480 alone could do it so you'll be fine.
Steam:pcmaster160
DST4ME
Posted: 05 Oct 2011 at 12:54am |
Originally posted by Doc
Anyone know how to change a video card without breaking stuff?  |
lol if you are serious have a look here, but that is for adding a second gpu, you will be doing the same thing with the exception of changing gpus so the sli bridge stuff you can skip.
Edited by DST4ME - 05 Oct 2011 at 12:56am
Posted: 05 Oct 2011 at 6:49am |
Muggz, like maxyme said, sli480s will play great  IMO. If my gtx560 plays and looks very good on high, in my opinion, sli 480s should play ultra smooth and fast. Everyone has a different definition of what looks smooth but to me, if I hadn't turned on Fraps utility to post the frames, I would've thought the frames alot higher. Next....Can't wait to check-out Skyrim  If that plays as well then my ODE 0 was well worth it.
Doc
Posted: 05 Oct 2011 at 11:15am |
lol if you are serious have a look here, but that is for adding a second gpu, you will be doing the same thing with the exception of changing gpus so the sli bridge stuff you can skip. |
Thanks
DST4ME
Posted: 05 Oct 2011 at 12:29pm |
@Muggz sli 480 is like sli 570 so thats more then enough.
@Doc you are welcome
Doc
Posted: 05 Oct 2011 at 10:12pm |
Card changed. Easy, thanks again. Not sure what to make of my fps. It really doesn't seem to matter my settings. I get roughly the same fps. Oddly I get higher fps on Ultra than on medium?  Beta thing? Ultra 45-60. Medium 40-45. High 40-50. BC2 shows 120 fps maxed out. Card is quiet and much cooler than my 275.
Edited by Doc - 05 Oct 2011 at 10:13pm
Posted: 06 Oct 2011 at 9:20am |
Doc, I think it is a beta thing. When I try ultra the frames stay in the high 30s and low 40s, like on high, and the same frames no matter what AA or AF setting I select. Medium settings were a little better. Ya, your gtx 570 should be about 20% better than 560, it seems. Like others have said for months to new config buyers, to get consistent 60-70+ frames a sli setup, even 560, is needed, at least by beta standards. But low 40s plays great. Just a thought.. I know nothing of server and MP coonections, and was wondering if these inconsistent or just wrong frames is a product of servers for the Beta?
Edited by bprat22 - 06 Oct 2011 at 10:17am
darbebo
Posted: 06 Oct 2011 at 11:40am |
@ bprat22,
yours is ode 0 rite? if so, without an SSD, how fast/slow does window starts? and how fast/slow does bf3 beta gets "loaded"?
what other games do you play that you can show me how fast things load? I'm deciding if getting SSD on a 1x570 vid card is even justified
Posted: 06 Oct 2011 at 11:46am |
Hi darbedo, I'm shutting everything and will get back to ya. Never really clocked it.
Here it is... Win7..1min 30 sec to clickable icons BF3...from Origin to BF3 to spawning....1min 30 sec Civ5...to saved game and play....1min 50 sec BF2...to single player action...1min 20 sec Dragon Age Origin...to a saved game...1 Min exact Oblivion...again, to a saved game and in the action...20 sec Yep, and ODE 0, no SDD.
Edited by bprat22 - 06 Oct 2011 at 12:14pm
darbebo
Posted: 06 Oct 2011 at 2:09pm |
hmm, interesting. i guess it's not that bad... but hmm..ok, great info. THank you!
Bizhound
Posted: 18 Oct 2011 at 7:04pm |
I just bought the Ode Level 2 and everything I read indicates I should be able to play BF3 smoothly. I was wondering about my monitor I picked up a 24" 120hz should that help with the way it runs off the GPU?
Chassis Model: Digital Storm ODE Level 2
Display: ASUS VG236HE Black 23" 3D
Processor: Intel Core i7 2600K
Memory: 8GB DDR3 1600MHz
Hard Drive: 120 SSD
RAM: NVIDIA GeForce GTX 580
