Best experience
Post Date: 2010-03-28
tom_p12 View Drop Down
  Quote tom_p12 Quote  Post ReplyReply bullet Topic: Best experience
    Posted: 28 Mar 2010 at 1:25pm
Had my Digital Storm system for six months now and could not be more pleased. I love it. Due to budgetary constraints (no job at the moment) mine is basic rig.
Digital Storm Desktop 167935
System Configuration:
Chassis Model: Special Deal Hot Seller - HAF 922
Processor: Intel Core i5 750 2.66GHz (Quad Core)
Motherboard: EVGA P55 LE Edition (Intel P55 Chipset)
System Memory: 4GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Power Supply: 700W Digital Storm Certified (Dual SLI Compatible) (Silent Edition Recommended)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x)
Video Card(s): 1x NVIDIA GeForce GTS 250 1GB (Includes PhysX Technology)
Extreme Cooling: Standard Factory Heat-sink and Fan
CPU Boost: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade)
I had shopped for months and the reviews on this forum and Digital Storm's very informative website convinced me. From the time I placed my order I was treated like their best customer. The computer arrived in excellent condition and has performed flawlessly from the minute I turned it on. It's used for general computing as much as gaming and the speed is amazing.
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
       Operating System                                  Microsoft Windows 7 Home Premium 6.1.7600 (Win7 RTM)
    Date                                              2010-03-28
    Time                                              11:50
--------[ Overclock ]---------------------------------------------------------------------------------------------------
    CPU Properties:
      CPU Type                                          QuadCore Intel Core i5 750
      CPU Alias                                         Lynnfield
      CPU Stepping                                      B1
      Engineering Sample                                No
      CPUID CPU Name                                    Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
      CPUID Revision                                    000106E5h
    CPU Speed:
      CPU Clock                                         3620.8 MHz  (original: 2667 MHz, overclock: 36%)
      CPU Multiplier                                    20x
      CPU FSB                                           181.0 MHz  (original: 133 MHz, overclock: 36%)
      QPI Clock                                         3258.8 MHz
      Memory Bus                                        724.2 MHz
      DRAM:FSB Ratio                                    4:1
    CPU Cache:
      L1 Code Cache                                     32 KB per core
      L1 Data Cache                                     32 KB per core
      L2 Cache                                          256 KB per core  (On-Die, ECC, Full-Speed)
      L3 Cache                                          8 MB  (On-Die, ECC, Full-Speed)
    Motherboard Properties:
      Motherboard ID                                    65-0100-000001-00101111-102309-LfdHvdImc$1E653A39_BIOS DATE: 10/23/09 16:17:15 VER: 08.00.16
      Motherboard Name                                  Unknown
    Chipset Properties:
      Motherboard Chipset                               Intel Ibex Peak P55, Intel Lynnfield
      Memory Timings                                    11-11-11-29  (CL-RCD-RP-RAS)
      Command Rate (CR)                                 1T
      DIMM1: Mushkin 991585 (996585)                    2 GB DDR3-1333 DDR3 SDRAM  (9-9-9-24 @ 666 MHz)  (8-8-8-22 @ 592 MHz)  (6-6-6-16 @ 444 MHz)
      DIMM3: Mushkin 991585 (996585)                    2 GB DDR3-1333 DDR3 SDRAM  (9-9-9-24 @ 666 MHz)  (8-8-8-22 @ 592 MHz)  (6-6-6-16 @ 444 MHz)
    BIOS Properties:
      System BIOS Date                                  10/23/09
      Video BIOS Date                                   02/19/09
      DMI BIOS Version                                  080016
    Graphics Processor Properties:
      Video Adapter                                     Zotac GeForce GTS 250
      GPU Code Name                                     G92GTS  (PCI Express 2.0 x16 10DE / 0615, Rev A2)
      GPU Clock (Geometric Domain)                      738 MHz  (original: 740 MHz)
      GPU Clock (Shader Domain)                         1836 MHz  (original: 1836 MHz)
      Memory Clock                                      1101 MHz  (original: 1100 MHz)
I started my career as a computer tech and have had many in my home since 1980. The build quality of this one is the best I have seen.
I hope to add components as my budget allows. So far the only upgrade is a Cooler Master Hyper 212 Plus with 2 120mm fans. It was easy to install in this chassis and works great.
I highly reccomend Digital Storm. This is an excellent computer and they are a pleasure to deal with.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 28 Mar 2010 at 4:32pm
Hi Tom, thanks for sharing your system with us. You really get a clean install with DS and the HAF cast. I wonder how you got over clocked but no fan upgrade. I guess the i5 runs cooler than the i7.
cswiacki View Drop Down
  Quote cswiacki Quote  Post ReplyReply bullet Posted: 28 Mar 2010 at 9:16pm
Looks good, DS really puts in a good effort for their customers.
OutlawedPanther View Drop Down
  Quote OutlawedPanther Quote  Post ReplyReply bullet Posted: 28 Mar 2010 at 11:32pm
OooConfused very nice!
  Quote tom_p12 Quote  Post ReplyReply bullet Posted: 29 Mar 2010 at 10:42am
The case came with a 200mm side fan. I temporarily removed it at Christmastime to show off the internals to guests. It's back on.
ShadowStar View Drop Down
  Quote ShadowStar Quote  Post ReplyReply bullet Posted: 29 Mar 2010 at 1:36pm
That is a great looking machine!Ermm
Walking the line between realities
Bullseye View Drop Down
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 29 Mar 2010 at 2:47pm
Awesome Dude!!!
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 01 Apr 2010 at 12:48pm
Nice looking rig!  Thanks for the pics! Smile
sirsiddius View Drop Down
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 01 Apr 2010 at 2:14pm
Is that a a stock intel cooler, my word I haven't seen on of those in ages.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Apr 2010 at 3:58pm
ya stock cooler, 3.6Ghz oc very nice
great looking build too, congrats
  Quote tom_p12 Quote  Post ReplyReply bullet Posted: 02 Apr 2010 at 12:55pm
Shortly after receiving my new machine I installed a Cooler Master Hyper 212 Plus with an additional Cooler Master 120mm blue LED fan. It looks good and cools great. However the original Intel cooler worked fine, I imagine due to all the fans and the excellent air flow through the case.
Sodius View Drop Down
  Quote Sodius Quote  Post ReplyReply bullet Posted: 03 Apr 2010 at 12:26pm
Awesome, looks clean and neat inside. Enjoy that beats. Ermm
This page was generated in 0.1328125 seconds.
