Best Air Cooled CasesPost Date: 2014-04-24 |
Dax Doomslayer
DS Veteran Keeper of the commas Joined: 29 Apr 2012 Online Status: Offline Posts: 4743 |
Topic: Best Air Cooled Cases Posted: 24 Apr 2014 at 2:15pm |
Hi Folks,
I've been trying to decide on a case once I get set to order in the next couple of months (waiting for the i7 4790K chip). I'm more than likely going to air cool so I'm looking for some of the better options for that. Looking at the options DS has, it would seem the Air 540 is now the best air cooling option? While I like the look and it gets pretty solid reviews, there does seem to be a potential issue with heat on the power supply/hard drive side. Is this the best option DS has in stock for air cooling? Does anyone know? I was all over the Haf-X until DS decided not to sell it. Thus, currently I'm looking at the Haf-X and the NZT Phantom 820 but figured I may as well expand the search as I'll have to special order it potentially. I'm not thrilled to special order as that's money that could be going into the components as opposed to a stocking fee type of thing but I figure I may as well do some due diligence. I'm fine going full tower but I also don't want to spend crazy money on a case as some of these cases can get pretty extravagant. I'm figuring up to about $300 or so is pretty much as far as I want to go. Any input is appreciated. Thanks for your help! Edited by Dax Doomslayer - 24 Apr 2014 at 2:15pm |
Quote Reply Posted: 25 Apr 2014 at 3:32am |
The HAF-X 942 is a great case. But the Carbide Air 540 is amazing. It's a great pick up. Your PSU shouldn't produce too much heat, and most nice psu's now a days (especially the corsair) monitor their heat/temp automatically to turn on and off their fans. As for your SSD's and HDD's. They also shouldn't be generation so much heat to worry about. Honestly, I'd put those fears away.
With the Carbide Air 540, you can load it full of AF120's and AF140's with is Corsairs high air flow fans. I'd even drop a nice Corsair H100i at the top of the case with some SP120's. You'll have some great air coming in from the front and top, and exhaust through the back. Amazing positive pressure to keep dust to a minimum, quite, and good flow. If you want air, I do recommend the Air 540. |
Quote Reply Posted: 25 Apr 2014 at 4:13am |
Easily overlooked, but the 540 does have 2 drive cages below the mobo for primary drives. Plenty of air there.
Quote Reply Posted: 25 Apr 2014 at 8:32am |
bprat be lurking on all my posts early as hell this morning. Every where I go, he was quick to follow.
I feel stalked. |
Quote Reply Posted: 25 Apr 2014 at 8:46am |
OK. One more and I'm done.
Ragevirusqq
Newbie Joined: 18 Feb 2014 Online Status: Offline Posts: 95 |
Quote Reply Posted: 25 Apr 2014 at 9:57am |
check out the thermaltake core v71 great for both water and air.
Quote Reply Posted: 25 Apr 2014 at 10:21am |
haha, bprat, you would... Touche' good sir... touche'
