Behemoth SSD upgradePost Date: 2014-08-30 |
MagicAmmo
Newbie Joined: 23 Aug 2014 Online Status: Offline Posts: 25 |
Topic: Behemoth SSD upgrade Posted: 30 Aug 2014 at 10:07am |
I have no Idea how to install an ssd into this laptop ive never messed with laptops before is there some sort of pdf telling me exactly witch screws to take out and what not lol. I know where the HDD is would the SDD slot be directly on the other side?
please get back with me |
Behemoth
Intel Core i7 4810MQ 8GB DDR3 1600MHz 1TB 5400RPM HDD 2x SLI (NVIDIA GeForce GTX 880M 8GB with NVIDIA Battery Boost + NVIDIA Optimus) Microsoft Windows 8.1 |
MagicAmmo
Quote Reply Posted: 30 Aug 2014 at 10:31am |
also could I use this? http://www.amazon.com/gp/product/B00GSJ9X4Q/ref=amb_link_396759842_2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=right-3&pf_rd_r=15MWN61MGWE13Y79907N&pf_rd_t=101&pf_rd_p=1685288042&pf_rd_i=507846
Behemoth
Quote Reply Posted: 30 Aug 2014 at 10:59am |
If you go to the Upgrading your computer part of the user manual, it'll show you how to remove the 1st HDD to get at the slot underneath for access to the 2nd HDD/SSD slot. It'll say that any 2.5" SSD with a height of 9 or 7 mm or so will fit. If one is 9.5mm the other might have to be 7mm . Check the manual to be certain, but they do stack on each other.
If you put in an SSD for your operating system, you'll need to install the OS from disc to the SSD, reboot it with the older HDD unplugged so Windows knows which drive to use for OS. After that, you can plug in the old HDD, with power off, and use it just for data, etc. That's how it work for desktops, anyways. I haven't done it for laptops but I'm assuming its all the same thing. Hope this helps. Maybe others with more recent laptop experience will chime in. Edited by bprat22 - 30 Aug 2014 at 11:15am |
MagicAmmo
Quote Reply Posted: 30 Aug 2014 at 12:01pm |
Behemoth
Quote Reply Posted: 30 Aug 2014 at 12:15pm |
I believe you could just use that WD drive in place of yours. I think the WD dual drive is 9.5 mm thick so if the HDD in your laptop now is also 9.5mm then this new drive might not fit with it. It might be cheaper to keep your HDD and get a separate larger SSD , larger than the 120gb SSD in the dual drive for less money to add to it, but up to you of course. It's all good.
MagicAmmo
Quote Reply Posted: 30 Aug 2014 at 1:36pm |
Behemoth
Quote Reply Posted: 30 Aug 2014 at 1:44pm |
Sure. It holds 2x 2.5 drives, so any combo works. Just have to make sure of their thickness. With the dual WD at 9.5 mm another SSD at 7mm should fit. Check the specs.
I think the Behemoth also can hold mSATA drives. It's a mini SSD drive , no casing, just a board, that fits mSATA slot next to the bottom ram sticks. Here again, check the specs. |
MagicAmmo
Quote Reply Posted: 30 Aug 2014 at 1:48pm |
Behemoth
Quote Reply Posted: 30 Aug 2014 at 1:57pm |
You're welcome.
After looking at the specs, I think both drives can be 9.5 mm thick. Not sure it's a concern but just throwing it out there. Let us know how it goes. We love upgrade stories. |
