Hi audiopanik......Welcome.
The Avendum level 3 has tri-sli, 3x gtx680. Across 3 monitors that leaves a single 680 for each monitor . For 24" monitor and I'm assuming 1920x1080 resolution, you will get BF3 and most games playing on ultra in the mid-60 fps on average from all tests I've seen. That's average, which means at times it'l go much higher and times it might dip into the low 50 fps. Great gaming, but some want 60+ fps always.
I personally would rather have a single 30" monitor at 2560x1600 resolution that this setup would play maxed out with room to spare, but that's just me.
As far as crashing and heat issues....The case is brand new and I can't believe DS would put this together, with all their testing, with any issues like that.
Hope this helps.
