Aventum IIPost Date: 2014-11-28 |
Bwillz
Newbie Joined: 28 Nov 2014 Online Status: Offline Posts: 2 |
Topic: Aventum II Posted: 28 Nov 2014 at 9:06pm |
Simple question is it possible to configure a Aventum II with out the extreme water cooling option I love the case but I have no idea how to keep up the maintance on a water cooling system of that degree
Stay far from timid. Only make moves when ya heart’s in it and live the phrase sky’s the limit
Quote Reply Posted: 28 Nov 2014 at 10:37pm |
Hi Bwillz,
Yes you can build a Aventum without the exotic liquid cooling. But you are paying a high premium for the Aventum case and not using its best feature. I did use a Corsair liquid cooler on the CPU that uses a closed system with no maintenance. They have a great track record and are a good way to cool the CPU. This build needs to be tweaked a bit but will give you an idea what you can do. Here is a basic system without exotic liquid cooling. Configuration Code: 1104822 Cost: $4198 Specifications: Chassis Model: Special Deal Hot Seller - Black OPS Aventum II Exterior Finish: Onyx Black Matte Finish with Red Stand Trim Accents: - Not Available Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components) System Memory: 16GB DDR3 1866MHz Corsair Vengeance Pro (High-Performance) Power Supply: 1050W Corsair HX1050 Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) Storage Set 1: 1x SSD (250GB Samsung 840 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Windows OS: Microsoft Windows 8.1 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) If you really don't want any liquid cooling in your system then here is a full air cooled system on the Velox case. Configuration Code: 1104845 Cost: $3616 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Velox Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components) System Memory: 16GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 850W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (256GB Samsung 850 PRO) Storage Set 2: 1x Storage (1TB Seagate) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio AIR: Stage 2: Noctua NH-D14 SE2011 Extreme Performance for CPU Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) To really build a system we need to know your budget and what monitor/monitors resolution you plan on using. Frank Edited by FrankW - 28 Nov 2014 at 10:39pm |
Bwillz
Quote Reply Posted: 30 Nov 2014 at 10:17am |
Thanks for the info i think I will go for something less extreme this will be my first pc I've had only macs till now
Quote Reply Posted: 30 Nov 2014 at 12:58pm |
Hi Bwillz,
We can help you pick or build a computer if we know your budget and the monitor/monitors you are going to be using. Frank |
