Aventum control panel softwarePost Date: 2015-03-17 |
mavonauto
Newbie Joined: 17 Mar 2015 Online Status: Offline Posts: 2 |
Topic: Aventum control panel software Posted: 17 Mar 2015 at 12:54am |
Hello,
Hope one of you Aventum owners with cyro-tec can help me. The original owner seemed to have wiped out the software link to the control panel (fan and light control). I've asked DS for a copy many times but for whatever reason they never get back to me. Can someone send me a copy of the application? Frankly, I did receive a copy from a third party but it was not typical in that it didn't install or show in my Windows Control Panel "programs" list. Also, I can't identify any drivers associated with it. When I run it I always get an error message that my USB connection is bad (I know its good). Along with the error message is the image associated with the Aventum control panel and it says it's using com port 9. I got my USB cable connected to MB USB port 910 (9 and 10) and have switched the conn with no avail. Tried safe mode, no go. Tried removing "signature required" (windows 7) and still no go although there is a device driver that is unrecognized in my system due to not being signed but mfg is unknown. Any help would be appreciated as I'm running CFD and my temps are getting very high. The CPU fans (all 6) seem to be running at very low speeds and I'd like to speed them up to see if the temps fall. That's where I need a working copy of Aventum/cyro-tec control panel. Thanks, Mark. |
Quote Reply Posted: 17 Mar 2015 at 4:22am |
try sending an email to alex at [email protected] im sure he can help you out
Admin Group Digital Storm Supervisor Joined: 04 Jun 2012 Online Status: Online Posts: 16314 |
Quote Reply Posted: 17 Mar 2015 at 2:47pm |
I received your email and I'll be in touch and work with you on a solution there.
mavonauto
Quote Reply Posted: 17 Mar 2015 at 4:51pm |
Alex,
Thanks a bunch. Solved problem and everything is working fine. Very good work. |
