ASRock Z97E-ITXPost Date: 2014-05-27 |
mserougi
Newbie Joined: 13 May 2014 Online Status: Offline Posts: 4 |
Topic: ASRock Z97E-ITX Posted: 27 May 2014 at 4:40pm |
What do you guys think of the ASRock Z97E-ITX board? So far it's the one board that I've seen that's more future-proofed than anything out there if it comes about the Z97 chipset, and it has a couple more features than the ASUS Z97I-PLUS. Thoughts on putting that in a Bolt 2 system if a Z97 Maximus Impact is not made available?
Quote Reply Posted: 28 May 2014 at 2:20pm |
That ASRock board does have some features like SATA Express that the Z97I Plus doesn't have. Computex is right around the corner...
mserougi
Quote Reply Posted: 28 May 2014 at 3:44pm |
Yes indeed. I'm on a tight timeline for a Bolt 2 but I also don't want to go for a Z87 Impact just to have ASUS reveal a Z97 Impact in a few days, cause then I would most definitely , come on Computex!
I read stories of ASRock failing for some, so not exactly confident in the quality of their boards. I also read that they're the third largest motherboard manufacturer which is kinda weird since not many are reviewing their boards. |
mserougi
Quote Reply Posted: 29 May 2014 at 12:01am |
Well this won't fit in a Bolt but at least we know an Impact VII will be released from the compatibility list: http://www.asus.com/Motherboards/ROG_Front_Base/
Good news! |
