That wouldn't be a problem for me.
But you know that it is not just the controller to be installed?
Fill level tubmeter (not going to use it)
Water temp sensore in/out
Water flow meters
Water pumps (these pumps are not the greatest)
Air temp sensore on Hardware and on case temp
Small Water block (Pic of Block below)
Here is a demo of it working
You guys would have to configure it to a certain extent to build the system and test it.
Not sure it will be worth it.It is one thing for me to install and configue it and enoughter for you guys, because there's just so much tidies work involve.
This is like a computer within a computer, ones it is set up it will do everything automatically controls the water flow rate ,fanspeeds ,Shut down computer ect...
This LED controller has like 32 screens for configuration and Monitor everything.
I(we) need to iron everything out before I consider it.
