Apollo Titan Build (need guidance)Post Date: 2015-05-29 |
Arkade_Kalamity
Newbie Joined: 29 May 2015 Online Status: Offline Posts: 16 |
Topic: Apollo Titan Build (need guidance) Posted: 29 May 2015 at 12:31pm |
Hello all, new to the forums. I need some advice building my dream pc.
Budget is 3000-4000. I'm trying to min/max my build as much as possible without going over budget, or the girlfriend finding out. I could use some help figuring out what can I upgrade or downgrade, or some general feedback on this build. Never spent this much on a pc and want to be thorough. Oh, this pc is strictly for gaming. My specs so far: $4006 Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS MAXIMUS VII HERO (Intel Z97 Chipset) (The Ultimate Power Platform) System Memory: 16GB DDR3 1866MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 1050W Corsair HX1050 Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: !CLEARANCE: 1x SSD (500GB Samsung 840 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless PCI-E ASUS PCE-N53 (Dual Band Performance) (Supports 802.11n/g/b) Graphics Card(s): 1x NVIDIA GeForce GTX TITAN X 12GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU Cooler (Extreme Performance) H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: Please Prioritize: Ship Within Four Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Edited by Arkade_Kalamity - 30 May 2015 at 7:58am |
Quote Reply Posted: 30 May 2015 at 3:41am |
Hi Arkade_Kalamity..... Welcome to the forums.
As-is that is a real nice build. If you want to save a few bucks and not impact gaming performance, you can drop the i7 cpu for the i5-4690k. The i7-4790k's hyperthreading does help in a lot of apps, multitasking, etc. but not so much for gaming. The Hero is tops in mobo but unless there's something specific on that board you need, select the Sabertooth for its added warranty and just a quality board. You could also change the 850watt for the EVGA 750watt unless you plan on adding another card in sli. Change Seagate HDD for the Western Digital Black for a more reliable and longer warranty. Looks good and hope this helps. |
oldlady RPGer
DS Veteran One of the cool kids Joined: 09 Sep 2011 Online Status: Offline Posts: 1080 |
Quote Reply Posted: 30 May 2015 at 3:58am |
Second what bprat22 says. My Sabertooth is running strong after 4 years.
I love your build however. And the Apollo is awesome. |
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 6:19am |
Thanks for the replies!
Another quick question. If I decide to run 2 gpu (titan) in the future with this build, will 850w cover me? |
Quote Reply Posted: 30 May 2015 at 6:25am |
For sli Titan X the 850 watt would probably do it and some sites recommend it as minimum, but I personally would go for a 1000 Watt. Nothing wrong with a little headroom and better than crashes, roll overs, etc if the psu is stretched.
What monitor/s resolution are you using ? If its a 4K then sli Titan X would be nice. Edited by bprat22 - 30 May 2015 at 6:28am |
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 6:59am |
I plan to upgrade to 4k in the near future. Gotta save a bit more lol.
As of right now, I'm running 1980x1080. Current setup is -------- m17r4 connected to my Sony KDL-46W905A. Removed competitor name. Edited by Snaike - 30 May 2015 at 8:59am |
Quote Reply Posted: 30 May 2015 at 7:20am |
The Titan X is going to "smoke" your 1080p, smoke meaning in a good way.
For 4K, it being the equivalent of 4x 1080p monitors, the single Titan will still play games but at reduced settings. Sli would be the way. |
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 7:34am |
Agreed. That's why I figured I set up my build ready for 4k & SLI. Upgrade my power supply now, save up a bit, and buy a 4k set and another Titan later this year.
Till then, max everything in site on my 1080p. I'm about to pull the trigger, getting nervous now lmao. |
Quote Reply Posted: 30 May 2015 at 7:51am |
I find a glass of Merlot , or two, makes the decision to buy big a lot easier.
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 8:55am |
Lmao. Too bad I'm at work. I need to be sober though, if not, I'll end up with 4x Titan SLI.
Quote Reply Posted: 30 May 2015 at 9:03am |
Google "Large Pixel Collider"... Four Titans in the DS Aventum Case...
That's why you order sober. |
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 9:08am |
Holy hell.
Makes my build look like a clock radio. |
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 9:34am |
Anyone know if the Apollo/build/case runs load? Should I invest in some stage of noise reduction?
Quote Reply Posted: 30 May 2015 at 9:50am |
Noise is so subjective its hard to tell someone yes or no. It will be louder than a box store pc with single rear fan, but not loud in my opinion comparing it to the older ODE 600T case that I have. They are similar.
The noise packages.... stage 2 ... there really isn't anywhere to mount sound deadening material so save the money stage 1.. they will tweak the fan speeds in Bios or a motherboard included software program like FanXpert. You could also do it yourself. Pretty easy to do. Edit.... The Apollo 760T case does have a 2 speed fan control that the case fans will plug into. So, not sure DS would do anything there. The other fan, the gpu, they don't adjust but you can with MSI Afterburner for one. The cpu cooler fans are best left alone but can also be adjusted. Edited by bprat22 - 30 May 2015 at 10:03am |
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 10:53am |
Thanks for all the help!
Order placed!!! The waiting game begins... |
Gunner GzR
Newbie Joined: 17 Apr 2015 Online Status: Offline Posts: 58 |
Quote Reply Posted: 30 May 2015 at 1:01pm |
wow nice system .. Welcome to the DS Family
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 1:44pm |
Thanks! Glad to become a part of it! |
Quote Reply Posted: 30 May 2015 at 2:26pm |
Congrats on your order. You're gonna love it.
Arkade_Kalamity
Quote Reply Posted: 30 May 2015 at 2:38pm |
For sure!
Now I gotta find a nice 1440p monitor for it. And convert to 4k hopefully by the end of the year. |
Quote Reply Posted: 31 May 2015 at 12:16am |
Well done, congratulations and welcome to the DS family!!
Arkade_Kalamity
Quote Reply Posted: 31 May 2015 at 7:16am |
Thanks! |
Arkade_Kalamity
Quote Reply Posted: 01 Jun 2015 at 10:11am |
Stage 1.
Arkade_Kalamity
Quote Reply Posted: 03 Jun 2015 at 8:54am |
Stage 2 & 3!!
Quote Reply Posted: 03 Jun 2015 at 8:58am |
Getting there.
