Apollo buildPost Date: 2014-09-16 |
Author | ||||
MIKEUSA
Newbie Joined: 16 Sep 2014 Online Status: Offline Posts: 7 |
Topic: Apollo build Posted: 16 Sep 2014 at 8:14pm |
$4500 Expectations: medium gaming, CAD, presentations, video editing, small business work Usage: 8 hrs/day Special Needs: [Please Type Here] Saved Ticket #: [Please Type Here] Specifications: Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 5930K 3.5GHz (Six-Core) (Unlocked CPU) <br><strong></strong> Motherboard: ASUS X99 RAMPAGE V (Intel X99 Chipset) <br><strong></strong> System Memory: 16GB DDR4 2800MHz Corsair Vengeance LPX (High-Performance) <br><strong></strong> Power Supply: 850W EVGA SuperNOVA <br><strong></strong> Expansion Bay: Internal Digital Media Card Reader (Black) <br><strong></strong> Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) <br><strong></strong> Storage Set 1: 1x SSD (256GB Samsung 840 PRO) <br><strong></strong> Storage Set 2: 1x Storage (2TB Western Digital - Black Edition) <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX) Sound Card: Creative Sound Blaster Z <br><strong></strong> HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) <br><strong></strong> Internal Lighting: Internal Chassis Lighting System (Blue) <br><strong></strong> Airflow Control: Strike-X AeroCool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade) <br><strong></strong> Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) <br><strong></strong> LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) QUESTIONS: Enough/too much ram? Strike x aerocool requires airflow upgrade, did I satisfy that req? just overall thoughts, this is my first custom build. Thanks forum!! |
Quote Reply Posted: 17 Sep 2014 at 7:06am | |||
There really isn't such a thing as too much RAM. The CAD and video editing will be the biggest users of RAM. So, it really is dependent on what kind of work you are doing with that. The more complex, the more memory needed. Memory speed is less of an issue than the amount, so that is a place you could save a bit. Others can probably give you better advice on this. Letting people know what particular programs you are going to be using, would help them to give you better advice.
I think so, with the fan upgrade. I don't really know that a fan controller is really needed the Rampage has 8 PWM fan headers. Asus has very good fan control software to ramp up the fans as needed to keep the system cool. Though I believe this is limited to the CPU temp. So this is personal call.
Depending on the complexity of the video and CAD work, a larger SSD might be in order. It will speed up the work to keep the current project on the SSD. I would suggest suggest dropping the audio card, the Rampage comes with an isolated audio section and I expect that it offers very similar performance to the Sound Blaster. Let us know what kind of display(s) you plan on using. Particularly, the number and resolution for advice on the graphics card selection. Depending on the complexity of the CAD work a Titan maybe a better choice.
Happy to help. ;-) Edited by danjw1 - 17 Sep 2014 at 7:32am |
Quote Reply Posted: 17 Sep 2014 at 7:30am | |||
Looks like a great build to me.
Just to add to danjw1 advice..... If you're going to stay with a single graphics card then the 5820k cpu might be all you need and save you $243. The biggest difference between the 5820k and 5930k are the number of Pcie lanes. The 5820k has 28 lanes and the 5930k has 40 lanes of traffic. For single card, they both run at the full x16 lanes. For sli, the 5830k runs at x16x8 and the 5930k at x16x16. Even for sli, present cards will see very little difference between x16 and x8, but can't say about the future. There is a small base clock speed difference, but that's irrelevant with overclocking. It's in the budget so 5930k is nice. The other is if you need to shave some $$. Good luck. |
MIKEUSA
Quote Reply Posted: 17 Sep 2014 at 8:32pm | |||
Thank you for the input, I appreciate it !!
Last question (I think), I want UPS. Is the high end UPS that DS sells enough for my system? I would also have a 27" LCD plugged in, nothing else. I took your advices- knocked down the CPU, deleted the audio card and the fan controller. Thanks again for your continued advice forum! |
Quote Reply Posted: 18 Sep 2014 at 5:59am | |||
I don't do UPS, but my guess would be a unit that can easily handle a 1000 watt system for added headroom.
Others might be able to help. |
Quote Reply Posted: 18 Sep 2014 at 7:20am | |||
Dell I believe uses APC units on their website. You can go to APC.com and use their UPS calculator to find what works. It uses the system load, a percentage of headroom you want and the run time to calculate.
Hope this helps. |
