Apollo build thoughtsPost Date: 2014-08-03 |
jengel
Newbie Joined: 03 Aug 2014 Online Status: Offline Posts: 5 |
Topic: Apollo build thoughts Posted: 03 Aug 2014 at 4:14pm |
Hey all,
I'm a professional animator looking to upgrade from my MacBookPro. A buddy recommended Digital Storm, and I've been impressed with everything I've read so far, especially the friendly feedback on the forums. I put together a build and am curious if there are any changes you recommend. Are there enough fans? Is the mother board alright? I regularly use Maya (strictly for animation, not rendering or FX), Adobe Creative Suite, and mild gaming. My monitor is 24" 1920x1200, and I'm planning on using storage and peripherals I already have. Budget: ~2k Expectations: Fast box w/ rock solid stability and excellent customer service that wont need to be upgraded for a few years. Usage: Animation, Photo Retouching, Gaming, Video Editing Special Needs: None Saved Ticket #: 1022112 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Coridium <br><strong></strong> Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 4690K 3.50 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) <br><strong></strong> Motherboard: GIGABYTE G1.Sniper Z97 (Intel Z97 Chipset) (Onboard Creative Sound) <br><strong></strong> System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX750M Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (120GB Samsung 840 EVO) Storage Set 2: - No Thanks <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) <br><strong></strong> Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Thanks! Jeff |
Quote Reply Posted: 03 Aug 2014 at 5:46pm |
Build looks pretty solid. If you're doing work in 3D programs, I recommend switching to the 4-core 8-thread 4790K for better performance.
jengel
Quote Reply Posted: 03 Aug 2014 at 8:51pm |
Thanks for the good suggestion. Is the 750w power supply enough if I wanted to SLI with an additional GTX 780 down the road?
StealthG6
Newbie Joined: 13 Jul 2014 Online Status: Offline Posts: 77 |
Quote Reply Posted: 03 Aug 2014 at 9:01pm |
It should be enough, granted I haven't gotten my computer yet it's in transit but I am running SLI 770 with overclock with a 750 watt PS and from what I hear you wan't a PS on a good load and not a 1000 watt only at a 40% load.
That looks like a pretty good build btw.
Apollo
i5 4690K 3.50 GHz (Codename Devils Canyon) 16GB DDR3 1600MHz 2x Asus GTX 770 DirectCU II 4GB GIGABYTE G1.Sniper Z97 H20: Stage 2: Corsair H110 280mm Radiator |
Quote Reply Posted: 04 Aug 2014 at 2:57am |
Hi jengel.. I agree, that is a solid build. I would however up your psu to a 850watt if you want to sli the 780. Nvidia and most reputable test sites recommend the 850 watt as a minimum. The sli 770 is a safer bet with the 750watt because they draw less.
The 750 watt might be ok, and plenty do it, but you try to keep a psu at or below 80% usage of its rated power. More efficient, less heat and more stable voltage. Better psu can definitely go higher but why run the risk of resets, BSOD, shutoff, etc for another $50. Looks great and good luck. Edited by bprat22 - 04 Aug 2014 at 3:10am |
jengel
Quote Reply Posted: 04 Aug 2014 at 3:14pm |
Thanks, stealth & bprat!
I asked someone in customer service and they agreed, but recommended going up to a 1000 watt psu to SLI the 780. I think I am going to run with the Corsair b/c you get a much better warranty for $2 :) |
Quote Reply Posted: 04 Aug 2014 at 3:44pm |
Nice change. A lot less chance of issues.
jengel
Quote Reply Posted: 10 Aug 2014 at 9:09pm |
Thanks for all the help, everyone. One more question... If I opt out of getting an optical drive, how would I reformat/reinstall drivers? Will DS put that stuff on a flash drive?
Quote Reply Posted: 11 Aug 2014 at 2:51am |
Not sure. You'd need to ask DS. My guess is that would for a fee.
Quote Reply Posted: 11 Aug 2014 at 6:58am |
You could store an image of the original system as it shipped to you on an external drive. I use Acronis True Image for my backups. There are lots of options out there. I keep a folder on an external drive with all the downloaded software I need to get my system up after I do a reinstall. I also keep my activation keys on a file on the same drive. That key file I also have backed up to the cloud.
Here is an article of how to install Windows from a USB flash drive: http://pcsupport.about.com/od/windows-8/a/install-windows-8-usb.htm. Another option is an external optical drive. |
jengel
Quote Reply Posted: 12 Aug 2014 at 1:49pm |
Thanks everyone! I ended up going with the optical drive, and placed the order yesterday. Hit Stage 3 this morning!
Quote Reply Posted: 12 Aug 2014 at 1:54pm |
Congrats.
